Ultra Racing 4-point Engine bar~
Skyfiro A32
Hi bro,i was involve in an accident last month n my UR bar (engine bay) was "run alignment" which mean not in the position wif screw nut hole.Any 1 noe where can fix it?:confused:
how much the screw 'lari' from its position? a panel beating shop should be able to do the job.
HI DanzEterna thx for your reply ^^
here is the picha of my struc bar after "lari from its position"..
shud can consider not so serious?:confused::confused:
should be ok kot......dun worry...your bars could be bend back.......
if it's my car, i'll knock the chassis to align with the bar..
well.. my motto is to use the car until the end of its life or mine..
:biggrin:
Thanks for the joke zul...it helps a lot.
joke? what joke?
from the pics i can see that the UR bar is not bend in any way (from what i see la).. so, i assuming that the bar is still the correct measurement for that model..
the one that is bend is the chassis.. due to accident.. so, if it was me.. i'd knock the chassis to align to the bar..
but that's only my opinion.. it's up to d owner..
Gudluck :burnout:
true also, not sure the bar bend or the chasis misalligned.
anyways, remove the bar & check the allignment like u check your spectacles.....
ur car accident with the UR bar intact is it?
:hmmmm:
Looks like you can't be sure if the accident repair aligned the body to its original state or if the ultra racing bar has been permanently bent from the accident.
why not give them a visit to compare their fresh piece of product to be sure? such products are manufactured with the guide of a Jig ensure consistency in their production line.
this is the easiest way to be sure. if your body aligns with the new bar, then all you need is a new bar. if the new bar doesn't align with your car, you may need to revisit the repair shop.
Ultra Racing (M) Sdn Bhd
No 25, Jalan Bukit Permai Utama Tiga, Taman Industri Bukit Permai, 56100 Kuala Lumpur.
Tel: +6 03 4280 4213
Fax: +6 03 4280 4313
Coordinates: N 03° 6.774' E101° 45.453'
Business Hour : Monday - Saturday 9.00am - 6.00pm
* Close on Sunday and Public Holidays.
They open everyday, including sundays and public holidays
