Perdana V6 Community Forum *
neuro...
last time i adjusted to -0.8. the angle increased after a while kot......
if the mechanic is professional enuf to press your camber, they will know how to do it.......
how u adjusted ur camber? hehe..
---------- Post added at 12:13 AM ---------- 6 hour anti-bump limit - Previous post was at 12:11 AM ----------
kenny, seriously 10,8 is hard.
if u can take it, ok la.
but if u want a bit comfort, then take softer rates..
ya meh? last week my fren install the HWL front 12 k and rear 5k...
maybe i try to sit his car 1st....coz many ppl ask me to change 12k....i scare too hard and my body koyak....
less sound, get semi-synthetic oil.
u dont want any tappet sound, get mineral oil.
ok thanks bro...
---------- Post added at 06:48 AM ---------- 6 hour anti-bump limit - Previous post was at 06:47 AM ----------
'Tik tik tik' sounds like a time bomb inside your engine. Please get an explosive expert to check.:biggrin:
hahaha....:biggrin:
yeah, check your tie rod end & rack end as well......
sorry danz.... so busy last few week back..... already check the tie rod.... oni at left drive shaft bushing koyak... where else ok....
when i jack the front right tyre... i just gerak2 kan tyre tu, ade bunyi macam bearing dekat drive shaft yang sambung ke gear box? ape problem tuh yek?
futher more, the temperature engine naik bila naik bukit..... hmmm confius....
isit the wheel bearing? sound like besi bergeser is it?
try checking your radiator cap 1st...see if its 0.8 bar & the spring inside still works...
yup..... mcm besi bergeser.....
radiator cap 0.8 bar.... but when open it, mcm loose... spring pun lembut jew.... radiator cap boleh jadi temp engine overheat kew?
one noob question, can 225/55/16 tyre can fit to perdana?
thanks alot...
DanzEterna said:
wat is that bro? how much?
Is some kind of oil treatment I buy quite sometime already that tiny bottle cost 100+ ringgit but can use for many times. It is high density oil treatment. Next time you come JB we try the effect if ok then you buy.
---------- Post added at 03:36 PM ---------- 6 hour anti-bump limit - Previous post was at 03:33 PM ----------
If your radiator water keep disappear it can be yr radiator faulty.
thanks alot...
can bro..find rim 16" with 8jj...
---------- Post added at 03:59 PM ---------- 6 hour anti-bump limit - Previous post was at 03:58 PM ----------
mines..wah rm100....okok will check it out see got sell at kakimotor anot...
