and kalau you nak tgk r32 subframe is gtr or not, just tengok dekat rear absober dia..knuckle gtr should be like attached picture not like gts (guna round bushing)so tgk kat 260 ni punya absober pun dah nampak..all gtrs using knuckle type rear absober..
And mainly, GT-R subframes (for rears) normally uses hook type to screw on the coilovers
http://img403.imageshack.us/img403/2904/dsc03647j.jpg
While GT-S's are normally bush types.
http://japaneseperformancecentre.com.au/site2/cache/com_zoo/images/coilovers_GREDDY_R32_30321a3e5181b1e06398da5c480b7a29.jpg
Most likely yes, they're quite alot of old 240z's or olden fairladies in the US that provide kits for the conversion namely to fit the IRS and R200 diff.
well, if u disable the hicas, there will be a free play of steering angle bu not muich but it will still effect the rear behavior. then again depends how u disable ur hicas. u can weld ur hicas rod, put spacers, replace the rack, change the whole sub frame, etc..
