OMG!! Have u guyz seen this muffler??!!
D7zul
Shah Alam
While i'm searching for an exhaust system for my beloved 'new' KE70, i stumble upon this muffler..
and I would definitely put this on my KE70 for daily driving & weekend drifting..
anyone have seen this in Malaysia?
http://www.holley.com/data/types/pictures/Warlock%20muffler%20graphic.jpg
Wow...someone Patented it..looks cool and unique...not sure if it is good :top:
what's not good about it?
it's a straight muffler + an S muffler built into 1.. juz need to screw/unscrew to switch from 1 to another..
:biggrin:
How is this muffler works ? I doesn't look like those valve operated muffler like Type Rs or super cars !?
I think most DC5 or even FD2R are using this type of "switching muffler" as their stock setup. I recon, Honda's design is much more better as the muffler will switch to straight flow during high-rev as there's a built-in valve inside the muffler itself.
But for KE70, just drop in a 20v with open ITB and fit a loudass muffler...drifutooo... that's the way you should be doing it :P
the cap have to remove manually via screws? very the leceh....if u rempiting then got road block...dun tell me wanna stop by the side of the road, get out, n pasang the cap?
this is better:
‪Varex remote control muffler.‬‏ - YouTube
and most people here either use the Aerospeed Exhaust Valve Controller which limits the amount of gasses n noise
or use a throttle body which redirects the exhaust to a secondary pipe which flows out a silent muffler)
varex, aerospeed, and tb can be controlled on the fly from inside the cabin itself...no need to manually close the loud exhaust
this is better:
u got a point there.. i think this muffler for the low budget guyz like me :biggrin:
need to plug the red thingy & screw to get S muffler..
unscrew for straight..
wats the price like?
dunno.. didn't find it in Malaysia
low budget??
i think its better to expect those type of mufflers to be very expensive...
u want cheap....start researching on the TB setup...even a faulty TB can be used..as long as the butterfly can open and close properly.
low budget??
if we got some1 who can copycat this muffler, sure cheap one..:biggrin:
Malaysia Boleh :driver:
:biggrin:
---------- Post added at 06:31 PM ---------- 6 hour anti-bump limit - Previous post was at 06:27 PM ----------
hahaha.. i dont like pencemaran bunyi..
:biggrin:
since you mentioned "low budget", may be you can find an old muffler, go to the ah pek shop for some welding and get the similar thing.
i know what you are thinking,
you wanna keep it as S-flow when driving on the street, low profile...
then when hit the car park for drifting, let all hell break loose...:biggrin:
Damn that's one nice piece of inovation! I think because it switches from straight to S, and not like those with a butterfly valve, it will have superior flow...
x force?
oh.. u guyz mean this?
http://www.xforce.com.au/img/products/p85_05.jpg
i'm using Y force for my levin.. :rofl::rofl::rofl:
---------- Post added at 12:14 PM ---------- 6 hour anti-bump limit - Previous post was at 12:13 PM ----------
yeap.. it's kinda split personality..
:biggrin:
