- Joined
- Jan 21, 2007
- Messages
- 400
- Points
- 1,563
The owner of this AMG Mercedes had contacted me some time ago as he wanted to ensure that his newly acquired pride and joy was properly protected from the harsh environmental conditions with a protective layer of Optimum Opti-Coat.
Optimum Opti-Coat forms a PERMANENT protective layer on the surface of the paint which helps protect the original paint from environmental damage. The Optimium Opti-Coat adds 2-3 microns to the thickness of the paint and is harder and more scratch resistant than the original factory paint. Optimum Opti-Coat also has superior hydrophobic properties which helps to ensure that dirt or other contaminants are less likely to bond with the paint and to make cleaning and maintaining the paint easier. Should there be any need to remove any stains which have bonded to the paint such as watermarks, the Optimum Opti-Coat can be polished while leaving the original factory paint untouched.
A common misconception with regards to coating is that the coat itself is the most important part of the process. The coating does matter but it is the surface preparation that makes all of the difference to the appearance of the paint and the coating is added as the last step to protect the paint. Any paint defects that are not corrected will be sealed in by the coating and hence it is critical to ensure the paint is properly corrected before coating.
This Mercedes Benz AMG E-Class took well over 15 hours and two-days to carry out the paint correction and Opti-Coating of the exterior and glass surfaces.
A....M....G....
Swirls and RIDS....
No need to PANIC!!!
Optimum Hyper Compound and Optimum Hyper Polish are here to save the day....
After many, many, hours... lots of sweat and a little beer....
Too many pics of the entire process to post here.
For the entire detail of this detail:
ProDetailing: Optimum Opti-Coat on Mercedes Benz AMG E-Class
A....M....G....
Swirls and RIDS....
No need to PANIC!!!
