idle problem.
Ashyie_Ferio
hey all. i need help troubleshooting.
my iacv is faulty i think. when turn on the aircon, rpm is too low. around 500rpm.
tried servicing it myself but i dont have enough power or know how.
a fella suggested is add an ficd. thoughts?:confused:
oh. i drive a honda eg8. d15b. stock.
there must be something is still dirty or how i not sure
witohut thinking so much wit headache, adding additional ficd from toyota is easy n headacheless job as it can straight away adjust the rpm from there without fixing anything of the car
thanks. i'll try my best the clean evry part first. if that doesnt solve the problem, then ask my formen to fix. thanks kenny.
:cheers:
mine the other way round when air con kick in RPM go higher can reach 1400rpm.....friend say maybe is the airflow sensor.......
me too got problem rpm jumping up to 1300rpm during idle after A/C cut-off....a/c cut-in drop back to +-700rpm...
the problem intermittenly happen...if it does happen,even turns off my a/c give no effect to cure it...
i've checked all vaccum hose related to TB/regulator etc etc...not yet check other things....MAF sensor connector,TPS connector checked and in good condition.....
Throttle body was just over 1year old brand new....if really TB kong again :banghead: me....
more or less happend to my car....after rempit2 with my evo3 engine...sudenlly rpm going crazy...bouncing up and down....but if ride as normal... rpm ok je....y ah?sometime when rempit secara lembut2 the rpm from 1k rise to 1.9k....y ah?haiya......
guys, i went to an aurcon shop n he said that my idle low when on air con beacuse too much pressure in radiator or sumthing like that.. so either can replace the whole assembly for rm200, or add another fan for 150.. my headache is, which is the problem now? is it my iacv or the radiator? grrrr.:banghead:
based on my experience with honda, if idle goes funky when air con is on/off, its more of less the iacv. urs is probably faulty. cycle is either too fast (high idle) or slow (low idle). i've had my fair share of iacv troubleshooting.
u should try to swap with a friend with similar engine, and see if it works. if it does, change the iacv, should be too exp. 100-150 bucks used. if its not iacv, possibly ur TB and the screw that comes with it.
im not sure whether is it the iacv, but im definately sure that is got nothing to do with the radiator.
not the radiator, the assembly beside the radiator. not sure whats its called.
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/184173_10150283451087248_773517247_7749508_259246_n.jpg
this part here. the guy said that there is too much pressure in there.
that looks like an aircond pipe..
:biggrin:
i think what they mean is either your a/c gass too much or your a/c compressor gonna be kong soon....
btw...update for my problem....yesterday evening want to go out for break-"fasting" started my car...suddenly idling quite high 1.6krpm....then jumping2 around like i install highcam...sh!t....pop the bonnet....adjust idler bypass oso can't cure,adjust distributor+idler bypass oso cannot....then adjust a bit my throttle bump-stop to maximum release...then remove my intake pipe and cuci a bit TB with thinner.....(not too dirty actually...just trying my luck).....
so after all done then start ok...still i think that not fully cured the problem.....like that mostly TB idler gear want to kong....ayoooo.....raya is coming car oso want new part.....
im not sure bout that. he said in order to solve the problem, either add another fan there, or replace with a new assembly. if only too much gas or something, cant they just drain the gas out?
me too facing this problem last year, send to the workshop & he solve the problem. Dunno wat exactly he does but if not mistaken he's say set the valve timing & distributor tuning:hmmmm:
