EVOMIVEC : the picture u r seeing is indeed a evo one laaa
vishnu : i guess u got the 38mm wastegate, so i guess if u get the 38mm also , do a small intlet and outlet pipe , cos 38mm is kinda overkill for a td04 , the actuator original flap is much much smaller than this.
a small example , u use a small straw and u blow air out, little air goes out although your mouth is the same size
now user a big straw , blow air out, lot of air goes out
thts the diffrence between the big n small wastegate, a big wastegate will let more exhaust air out, if its too big, it might cause boost drop n also lag, bt 38mm should be ok with a td04, just make the pipes smaller
if i was u, i will stick to the stock manifold ported nicely for better flow , the stainless steel for a td04 flange would be a waste
plug the wastegate at the o2 housing and not the manifold
like these
http://www.maperformance.com/products/map_DSM-O2-38-SS.jpg
simply awesome~! can i just use original GSR TD04L to do so? the downpipe with wastegate, and port it out remove the flapperhttp://www.jakelatham.com/1gDSM/projects/external_wastegate/images/fp_green_02.jpg
port it out, remove the flapper goodbye :D
