4AGZE drive shaft issue! Need help!
AE75
I just wondering,
1. 4AGZE driveshaft for LSD and non-LSD are different? and what are the side effect if using wrongly?
2. Brand new (CV joint) can be source able?
3. If need to customize from other car, so how to customize?
Because I'm using 4AGZE LSD speed gear, and having some issue on drive-shaft ~ Mechanic said is because I'm using non-LSD drive-shaft on LSD speed gear.
I thought, both use similar drive shaft... :hmmmm2:
I also same as you until my mechanic said the 4AGZE LSD drive shaft are abit longer than non-LSD drive shaft.
Once I source on internet and i found it, really have 2 type~:hmmmm:
as i know lsd and non lsd drive shafts are different.. but what i did not know is that u can match it.. and to answer ur question yes u can get new cv joint.. just take the sample to the parts shop:) i got mine new.. funny thing is the box said for ae86.. since when a86 got cv joint. lol
Parts shop I do tried my luck before, but end up only can found 4AGE CV joint & the 4AGZE CV joint still no luck~ Sad T.T
