Simplified guide to Engine Oils
good info izso...
at least this would be a guideline for noobie like me.
and remind me that the fact is, there is none one grade engine oil for all cars...or the statement of "best engine oil".... :listen:
which i find it BS and your article does make sense... :proud:
Is thr any ROYAL PURPLE engine oil disributor in penang?..
Maybe you can contact the distributor in Singapore to see if they have any resellers in Penang?
http://royalpurple.com/dealer-international.html
hello kitty...nice....
once bump with ultraman engine oil in spare parts shop somewhere in wangsa melawati
sadly i didnt recognize which ultraman is he/she:biggrin:
thank you very much for the info but can you enlighten me about changing oil which has passed its date? for example for semi synthetic after 5k km we know automatically its time to change the oil but what if its just a weekend car for example just reach 2k++km but the date has passed (usually 3-4 month) can we continue using the oil or change it? wht bout the filter continue to use it or replace?? thanks in advance:driver:
That's actually a good question. I don't have any scientific proof but I believe oil left alone eventually will be exposed to moisture and humidity fluctuations (rain, extreme heat) etc. Anything exposed to moisture can't be a good thing. So what I normally practise is I don't leave mineral oil longer than 4~5 months, semi's no more than 8 months and fully syns no more than a year. I'd change it even if it hasn't reached the mileage OCI. It might be overkill but better safe than sorry.
The oil filter is there to filter debris, sludge and whatever the oil managed to remove or leave behind. If the car rarely moves and hasn't reached the OCI, I wouldn't worry about it until you're ready to change the oil.
i tink shud replace engine oil before it passed the recommended date eventhou mileage is still very low.
this is because engine oil lose its capability over time and usage.
dats why OCI is determine either by date or mileage.
i ALWAYS change the oil filter whenever change the engine oil.
hope this helps... :driver:
different view i see anyway thanks for the answers bros:proud:
nice info...now i really now y last time i use castrol semi,my car leak after after that..so so la....
