Pakdamek
Hi....as the topic, is it suitable to change to an aluminum radiator for a street daily driven car?
Thanks.
Thanks.
Uh.. that's not entirely true.
Copper radiators dissipate heat better than aluminium radiators, but the main problem with copper is the welded joints and that's usually where the contaminants come from.
However Aluminium is way lighter and because of the way it's joined (not welded) it can be made thinner and wider so in most cases Alu radiators have more surface area than copper radiators so its efficiency is there.
Both are prone to corrosion so use your coolants wisely and try not to expose it to corrosive stuff like sea water, brake oil, etc.
Both types of radiators have their pros and cons. But having a high compression engine and a lot of other things done to my engine my stock copper radiator is still serving me well. Auto radiators are wider and bigger compared to manuals. Just get a higher speed radiator fan to help further cool it down.
thanks for enlighten me, so in my case, real life situation would a 2 row aluminium rad outperforms 1 row copper rad in cooling?
Most likely. But personally I'd say your benefits is a lighter radiator. And lightening the front end does wonders for handling! Throw in a CF hood and it'll be goooooooood
its true, when i had my battery moved to trunk i felt more responsive front end, took me awhile to get used to it at high cornering speed
cf hood might be a bit splurging but nice to have haha
hehe depends on people..i take note steering amount especially on my daily route so i can feel confidence driving faster everyday coz ill drive in same pattern
the kelisa has lightweight body, with stiffened chassis and suspension, steering becomes even more sensitive, so small change like that is easily noticeable hehe
heavier car can feel less difference i suppose, fun to drive fast coz u cant feel hehe
I wish I have cf balls like you all so that I can drive as fast as you all...but I have no car la...im just lorry/van driver...hmm
bengong punya statement....bebetul kene sumpah skyline tu jadi van baru hilang telur...
kekekekek
jk~bengong punya statement....bebetul kene sumpah skyline tu jadi van baru hilang telur...
kekekekek
for your case, its not needed at all. A bigger 2 row aluminum radiator cools better than a single row copper. However, this is provided your car needs additional cooling.
The stock radiator for the Satria is more than adequate even if you TC your car.
Btw, changing radiator alone will not improve cooling because its controlled by the thermostat.
