- Joined
- Dec 31, 2007
- Messages
- 275
- Points
- 1,528
i just had my battery relocated to the trunk and i could not be sure whether this had caused me electrical unstablity because im noticing small bouncing rpm when signal light is on during idle, the vacuum meter dims when headlight and signal is switched on
my car is not super audio equipped, only brighter PIAA headlamp, and the meter. i have 2 stabilizers and problem still persists
i just talked to a friend who told me i need to get a grounding wire from alternator all the way to negative terminal at the trunk coz i dont have one now, seems i have low alternator charging issue.
the pomen who did the mod only have 1 grounding cable to terminal which connects to the body
any suggestions?
any suggestions?
