(WTS) Kicker ZR120 & RF 120.2 2-channel Amp
ICE -In Car Entertainment
trxx7989
Letting go both of my amp which suitable for SQ entry level. Still in good condition. Both item Made in USA...not Cap Ayam or Helang!!
Kicker ZR120 2-Channel Amplifier - SOLD
Details:
stereo or bridged mono output
Tri-way capable (Tri-Way crossover required)
30 watts RMS x 2 at 4 ohms
60 watts RMS x 2 at 2 ohms
90 watts RMS x 2 at 1 ohm
120 watts RMS x 1 at 4 ohms in bridged mode
180 watts RMS x 1 at 2 ohms in bridged mode
stable to 1 ohm in stereo, 2 ohms in mono mode
frequency response 10-28,000 Hz
MOSFET power supply
discrete output transistors
silent turn-on/off circuitry
removable endcaps and logo plate
11-7/16"W x 2-15/16"H x 10"D
Specifications
Input impedance: 22 kohms
Maximum distortion at Rated power, 4 ohm stereo, 12.5-16VDC: 0.02%
Rated power 1 ohm stereo: 90 x 2
Rated power 2.66 ohm bridged: 180 x 1
Rated power 2 ohm bridged: 180 x 1
With built-in crossover
Rockford Fosgate PUNCH 120.2 2-Channel Amplifier - SOLD
Details:
Stereo, bridged mono or Tri-Way output
60 watts x 2 at 2 ohms
120 watts x 1 in bridged mode
MOSFET power supply and output devices
80 Hz low-pass, 120 Hz high-pass crossover, 12 dB/octave
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp
NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance
TRANS-ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
Selectable Punch Bass boost (0/6/12 dB at 45 Hz)
Speaker-level inputs
wat the age of the amps? best price?
