svt at cant reach 180km/h
Just installed RSM or sld then can remove the speed cut with out engine check light on
Just installed RSM or sld then can remove the speed cut with out engine check light on
nothing like that installed ... only wanna have fun ... not daily drive .. so dunn bother also .. :P
How do you do that bro? My SVT rpm almost reach 7k before 180kmh at 4th gear. So need to shift to 5th gear then get to speed cut
Kimi, he mentioned that the SVT is installed in his KE70. So definitely he's not using C52/C56/C160 gearbox for his RWD setup. Prolly he's using AE86 gbox which could have longer gear ratio which is suited for 16v. Basically 5th gear on the AE86 gbox for a 20v is pretty much useless. Correct me if i'm wrong...
my car ST at can go 180km, but cn't go 181km.. bcos have sped cut..
:driver::driver::driver:...
I drive a stock SE with a stock SVT inside. easily can reach 180 or 190 as bro levin818 said. even stock can reach 180, what if it is modified? 205 maybe? more maybe?
IMHO, if you want to keep it stock, just keep it stock. If you want to modify your engine, just go to the correct mech. otherwise your engine will screw up.
oh but this time around, I don't dare to speed up more than 140, after seeing a horrible accident occurred right in front of me
hahaaha. problem solved! oledi reached 180++ km/h. juz need skills to move my svt at. clearly im a noob here ^,^
good for u man .
cause i believe SVT and BT could reach way higher speed .
im using 4a-fe manual and can reach 170 with no problem .
nvr really tried 180 . too slow to reach that part, but the meter is still climbing :P
