Spacer 4 to 5 holes
thomzcruz80
Kuching
Hi guys,
izit possible if im using spacer as i mention above coz intend to use rim wif 5 holes juz by using spacer?
u'll felt your suspension current setup a bit softer than usual...
long time maybe put more stress on your knuckle bearing..but not that fast to spoilt.....
other than that if the spacer was in good quality then no problem...vibration also didn't exist :adore:
Hi guys,
4 lug to 5 lug adapter, you mean.
something like this..
thanx for the explaination bro..but how come the suspension will become a bit softer bro?
because of the spacer would put your rimm offset into wider stance....
and its simply put more leverage force on your lower arm+suspension
(short lever versus long lever which was easier to move??) but not too obvious....its just some ppl too sensitive on their car behavior....
