white_flame
From Facebook
3-stage VTEC? my friend has an EK3 with that.. seems pretty cool but seeing it scream woefully at 7k saddens me.. especially the sad CVT gearbox. CVT really kills those who have the hearts to buff up their cars.
hehehehe ... i have searched alot though thoose american forums .. and from my investigation hehehe ... there is one malaysian by the nick BIG[V] in these forums that seems to know alot about d-series engine ... wonder if he is here in ZTH hehehe ... please reveal yourselfwe need ur help
You and me both bro ... btw .. bro ur gb same like mine ... wonder if u use the S mode often ... hehehe ...
come on where are all the SOHC honda owners !!!
p.s. just got my ass handed to me by a stock neo cps ... haiyaaaa ... not good ...
campro also gettin fast nowadays ...
need to start modding ...
Thx for posting guys/sifu's ... will put the dohc vtec under consideration ...![]()
D15 series mid and hi cam is available at Powerzone.
But true, modding a D series costs will be too much. Better off do a swap with B series which is abundant. (Power-money ratio wise)
Just wondering for our local D16, ie ej9 how much horses for this engine?
Big[V];4330045 said:u can slap in any d series motor in but if you are thinking of putting d15b 3 stage + CVT, some chassis & undercarriage work is required to clear the massive cvt gearbox as the EF engine bay space is limited.
From carb based convert to EFI it's a hefty process. Make sure you get all the required components before you start. The last thing you'd want to do is frantically looking for parts when suddenly faced a hurdle during the swap.
Best recommendation is getting a d15b half cut. maybe pricey but much less headache. consider it a bit of extra for some peace of mind.
Big[V];4330276 said:you'd have to search for it online. d15b half cuts are not common as they are not popular swap choices.
Which year half cut do you have in mind?
Anybody ??? Takkan all main DOHC... where are the SOHC Vtec ???
I'm running on a D15B 16V non-vtec too..City Type-Z....you can get a few affordable upgrades like d-series light crank pulley, change to 4-2-1 manifold...etc...but will not increase the power tremendously, perhaps maybe 1 to 5whp if you are lucky. Dyno run stated at only 109whp.... :( perhaps maybe a 11 year old engine needs to do overhauling to maintained back the power...just aiming at 130whp to 150whp...this will be ideal for me.
wishing to do a mini-me conversion.....D15B lower block with a D16Z6 head...but the thing is...its so hard to find a good d-series foreman that can rely to do the conversion....from non-vtec to vtec is already a problem on which ecu to use....wiring to get...yet im running now a P3S ecu..which is super rare...not even a p30 ecu could fit in. Next, mini-me conversion also causes the compression ratio to be a high compression motor...running at 11.0:1 which you need to feed with higher ron octane. Stock is just 9.2:1...running at ron 95 already sometimes causing knocking....
