hi all, let's start a thread for all JZ engine users. let's share maintenance, modification tips & advice, share ur rides n any JZ sale/wanted parts here...
Currently an owner of two 1JZ-GTE both with single turbo. One 1JZ-GTE swapped in Rx-7 with R154 gear and exedy twin plate. Turbo Holset HX-40 almost equivalent to GT40R. 650CC injectors, HKS Fuel Cut Defender, Piggybacked with Apexi Vafc 2, Apexi AVCR boost Controller, running 1.8Bar on stock internals. Please don't ask for dyno reports as we don't have any dyno here in Pakistan :(. Another is Nissan Cedric old car currently going through swap with 1JZ-GTE W58 gear. Turbo Holset HX-35. 550CC injectors, HKS Fuel Cut Defender, Piggybacked with Apexi Safc 1, Turbo smart manual boost controller, will also run 1.8Bar on stock internal. And yes 1JZ-GTE can support 1.8Bar on stock internal. For drag races also tested 2.2Bar on stock internal. Then back to 1.8Bar, and engine is still safe and sound.
---------- Post added at 04:57 AM ---------- 6 hour anti-bump limit - Previous post was at 04:54 AM ----------
Saluran ahmedshaikhani - YouTube
Here is the video of my RX-7 with an AFR of 10 something. Running 1.2Bar boost. Had to hit rev limits because of traction issues. I was using normal street tyres.
---------- Post added at 05:08 AM ---------- 6 hour anti-bump limit - Previous post was at 04:57 AM ----------
Can't upload pictures of my Nissan Cedric don't know what's the issue. Currently car going through a process of fabrication.
guys sorry for asking a noob question here, isit possible to fit a wastegate to the original exhaust manifold? if yes where can i do it and how much am i looking to pay for it. my car is a hilux with 1jz-vvti.
Wanted to install a EMS to my E9 but duuno which brand should I go for! For light mod only !
Purpose to install cos need stable fuel supply to handle high boost! Correct me if I am wrong! I am newbie...
Anybody knows what's the minimum boost for the Toyota Starlet EP82 turbine? Going to use it for a bolt on turbo project.. Was wondering if the actuator could leak out to get around 0.3-0.4 bar only..
