Help me wif my upgrade of my 4age 20v
Ultraman71
Hi guys i am driving ae101 corolla.
my set up is 4AGE 20v quad throttle black top engine n 6 speed gear box..
running on high comm piston n stage 1 cams. at about 180+ horses now. i am actually looking to upgrade my car either bigger lower block or higher Cams or even both. and also looking for LSD for my gear box...
so guys any suggestions n sharing please write down. every ting contributed will mean alot to me!
Cheeers!
-Ian
180 hp..erkkk..
mind to share what you have done?
what ecu u used?
what cam duration?
What header + exhaust setup?
still use vvt?
your location..any graft to share and what dyno machine u used..
:biggrin:
180 hp..erkkk..
what ecu u used?
what cam duration?
still use vvt?
:biggrin:
Yeah. I wanna know too.
U can't put up horsepower based on ur mods.
Some mods decreases hp :biggrin:
haha graphs ya... soon i get it from my tuner.... well my whole engine fitted from japan... hmmmm soo called their lowest spec race engine... =.= dunno how true though cos i haven play wif any 4age black top soo i dunno hw fast my car is also... extractor using stock ones though...
---------- Post added at 02:41 PM ---------- 6 hour anti-bump limit - Previous post was at 02:38 PM ----------
thought of changing 310degree n 9.1mm lift... anyone tried this cams? is it driveable below 5000rpm?
180+ horse... I believe its more like on engine based on mods stated.
FYI, 180whp (wheel horse power) is more like stage 3 mods done up to the engine.
If you want more hp, you can consider:
Flowbenched p&p head with 3/5 angle valve cut
1.8 stroker kit,
Oversized hi-comp piston,
H-beam conrod,
Ogura clutch,
TRD cams,
Titanium retainers,
Uprated valve springs,
Race bearings
TRD 0.8mm metal gasket
Standalone ECU with COP setup
Velocity stack with CAI
Jasma extractor, 2.38" piping & straight flow muffler
Proper fuel delivery setup
If you want instant power, consider installing NOS as well ;)
and also hmmm i am running stock air box with fat tummy B series piping to cold air intake. u all tink will it b better than trumpet without cold air intake?
here is the pic hope nt too small lol
Cheeers!
-Ian
Ultraman71, do you happen to know hanracing?
