Good day,
Another Volkswagen need to update here. This car is a brand new 1week old ride, owner wash this car by himself with plain water after he got it. During inspection this car have only 15% of swirls and other than that is RIDS that may need wet sanding to remove. We cant expect the car will be in perfect condition once you got the car, even a BMW will have hologram issue once the owner got his car at the showroom.
The Jetta was delivered to me on Friday, weather was bad too.
looks good from far
closer inspection
cleaning begins at the wheel, Osren DFX to remove old dressing
and then OPC 1:3 on the wheel
wheel arch clean as well
after cleaning the wheels then move to cleaning exterior, number plate took out
clean rubbers
petrol tank
fog light
And then body was washed with ONR
After done cleaning and claying the exterior, tars at the rear lower bumper was removed with Osren Tar Remover
after
some glue stain on top of the roof
just wipe off with OPC
after
before
after
http://i1125.photobucket.com/albums/l598/munyoong2/VW%20Jetta/DSC04251.jpg
Paintwork inspection begins..
Found RIDS on the hood
after corrected
roof also found a deeper RIDS, i use 2000grit sandpaper to sand and then OHP to remove the sanding mark. Check out my video below how i do it!
rear bonnet before
after corrected
And last wiped down with IPA before coating
The maximum protection and reflection, Opti-Coat.
After pictures..
Thanks for reading
looks good from far
closer inspection
clean rubbers
petrol tank
fog light
after
after
before
after
after corrected
rear bonnet before
after corrected
After pictures..
Thanks for reading
jelly leh?
