Speed2horizon : dude... anything is more comfortable than stock FD2R suspension!
The N16 is not a light car. So if you test this sort of combination make sure it's on another N16. But gotta agree though, original N16 is really soft and it'll be hard to get that sort of comfort and performance at the same time.
I just had a thought, if it's some cornering performance you're looking for, why not just stick with stock absorbers and springs, but upgrade to thicker larger antiroll bars? In my own car (and after spending thousands) I've tested a couple of combinations with the 'cheaper' options (meaning no Koni / Bilstein, etc) I found that upgrading from 19mm to 23mm front ARB and from no rear ARB to 16mm made a humongus difference in cornering performance. More so than rock hard suspension mainly because it was more predictable and controllable compared to hard suspension which relied heavily on good tyre grip. Right now I'm using Hotbits Silver together with a tonne of bars and stuff. I think the Hotbits Silver rebound rate is a little too soft for my liking.
thanks guys for your advises..seem like i cant even change my suspension to adjustable for comfort ride..now, i think i want to install with shock absorber which is GAB,Hotbit for my sentra N16 and spring eibach pro-kit..is that ok..?? i heard alot of positive comment on eibach spring seems this spring are 100% from germany,rite..
