Straight Cut Gear box
YEN96
JB/SGP
wat is the difference between straight cut and normal gear box ???
wat is the purpose ??
if not mistaken straight cut is also the same as sequential gearbox...
pricewise, expect it to be more expensive than ur car....
No more need radio as a entertainment..coz music will come from g.box...so syiok..2 type-one still running sincro like sr20 rear drive.lucky if cut shop dont know its..and two is no sincro...cannot change gear when car not run....
wahhaha....how much to do straight cut gear box and wat is good abt straight cut ?
its good for racing because less power loss from gearbox....
normal daily car use angular cut gear due to less noise...but also less contact area thus some power loss and free play....while straight cut as name suggest....the tooth inside gearbox was straight and flat for full power transfer and minimal free play..hence the tight clearance and produce that awesome song when the engine winds up the rev and speed
