in a few more minutes,
proton basher will start to flame this thread
1.6 can go up to 500hp also la.. a mazda mx5 did that in Hot4s mag.. go check it out..
dont compare Mazda to a Proton. CamPro engine can be brittle if not properly done..pretty robust when properly done.
with "taufu" internals, the weak link is the crankshaft ( non-CFE model ), thin rods, thin valves, small oil galleries, small water jacket...how to control heat that is building up inside the engine itself ?
there's a fine line between driving it confidently ( reliable ) and destroying it the next second if one decides to pull so much horses.
maybe with stronger internals and improved lubrication ( circulation ), fueling, cooling, that much horses is achievable. not to forget, the "brain" must also be upgraded.. alot to consider.
Suddenly this thread reached 2 pages..
is 200 horses possible ?
are u still in 80's.?
use mr. google. it helps u to be in 2010 at least.
technology change everytings
my bad.. i though 1.6 NA.. sorry ya. if BOT 1.6 of coz can![]()
i doubt it.
1 horse weights an average 400kg~450kg, 200 horses is around 80000kg, thats 80 ton. No way in hell a Neo 1.6 campro can carry that many horses.![]()
i doubt it.
Lol... Lets get back to the point as i want to start the evo swap or mod"in my compo ,
spoken to speedworks and they say 200hp will blow the engine
most probably campro will blow with high boost..
even with NGV the conrod got broken.. it's the quality of material they use..
if it was me, i'd blow my engine 1st..
only after that i'll go search for a new engine with lots of power
Gudluck![]()
