holysniper
Hi bros, can share what is your oil and water temperature for your satria neo?
Thanks!
Thanks!
Lol.. y not use a oil cooler?
It is an oil cooler.
Just that i prefer not to use air-to-air oil cooler.
Wow, can share the setup with me?
Any pictures?
DIY?
Yup, DIY.
When we meet, i will tell u how its done. not really complicated..not really done neatly yet, but to me it works la..
Whoo nice!! I assume you are using the engine coolant to cool the oil? Cause I remember the Toyota Celica ST185 is also using a similar concept. IT has a water oil coolant. There is an outlet from the engine which will pipe coolant to the oil cooler and back to the radiator.
Exactly.
The outlet from radiator directly to the oil filter, and then joins back to the cylinder head.
It took me 2-3 days to finish this project..DIY mah..![]()
Salute!!! Very nice! Btw where did you get the adapter from? I also want to DIY oil cooler!!
just did some 170km/h runs on highway, water temp maintains at 85degrees, oil went up to almost 120degrees. Maybe the ELF 5w40 oil i am using is not good.. or should I invest in a oil cooler since I plan to go track.
