1.5 Siemen VDO to 1.8 Siemen VDO Problem
cheng_Y
Hi All,
I need an advice from those who experience before.
Situation as below.
1.Wira SE 1.5 Siemen VDO Throttle body damage.
2.I replace it with 1.8Siemen VDO Throttlebody (Purchase new from Proton Part Center @ RM556.36)
3.When I install it, the car idling not stable and sometime engine die/off itself.
4.What could be wrong? How to solve this problem?
5.I saw a lot article said the 1.8TB can Plug & play on 1.5 Siemen VDO engine, but now......(Never ending story):bawling:
6. Got ppl said, left the 1.8 throttle to calibrate itself for few minutes. And it will run in good condition.
Tai Kooo / Sifu:adore:..... Please help. I dont want waste the RM556.36......
Many thanks
1st of all, what are the things that have u changed? Is it the ECU or throttle body?
Is the throttle body electronically actuated or via cable? While physically the 1.8 throttle body can be fitted onto the 1.5 engine, the electronics may not necessarily be able to adapt to the different throttle body. You may need to have a diagnostic machine to reset and calibrate the throttle body sensor. Hope this helps.
to operate a 1.8 VDO TB u need a 1.8 VDO GTI ECU & dun expect a 1.5 VDO ecu can handle 1.8 VDO GTI TB even u can look for a half cut condition GTI1.8 ECU CEL will on due to no knock sensor detected so keep your new GTI TB & buy a new VDO 1.5 TB anywhere I am a 1.5 vdo user too cheers
it's okay 1.5 VDO are self adapt to simple mod like PnP head, mild cam,IHE(air intake, header/extractor & exhaust system) even a stroker kit but not for extreme mod lah Izso & me both are vdo user may u join us at http://s3.zetaboards.com/4G1series_Owners/index/ for more info , happy joining 4g1series
To get the answer correctly, I think need to open up the GTI Siemen VDO for some investication.
But, before do this. I heard ppl said TB need to be calibrate or reset before use. I think only this problem cause my car idling problem. Isn't????
Total of 7 pin out from the VDO TB - should have some article posted online.:confused:
Can any sifu share thier experience? many thanks.
Hello Bro, spot the different. Guess which one is original 1.5 and 1.8 Throttle body.
cheng,
pls join in 4g1series as member, then look for topic vdo throttle body modification, me lazy to type again, look for ahchapp GTI vdo TB with GTI ecu mod in wira 1.3 vdo only :p
Izso- Already read the article from 4g1X.
Left is the 1.8 TB
Rupa rupa wira also using VW system. Try check your's. I'm proud with VDO VW in my Wira SE.:smokin:
Left is the 1.8 TB
What VW system you talking about?
The VDO ECU is very adaptive and can handle most mods you do to your car. Like in my case stroke, enlarged bore, injectors, cam, etc. Stock ECU. But there's a certain limit it can handle I think and I've reached a stage where I want more out of the car. That's when problems come in. Most Piggybacks don't work except for reportedly Unichip and some say Works EMS-1. Otherwise we'll have to opt for standalones.
Hello Cheng,
You need to change VDO ECU (code: 0658) and add knock sensor to adapt the 1.8 VDO TB. The problem still happen and It will not self adjustment If you still remain to use 1.5 Siemen VDO ECU.
Otherwise, you need to buy a new/2nd hand 1.5 VDO TB.
The HP is the same. The Torque curve on the otherhand goes up like a rocket.
hi guys..im drvg wira Se 2005 aT n for sure vdo tb fr about 2 yrs oredi..but my prblm is the fC is too high n i dun knw wt to do:bawling:..pickup is very bad n some of my frenz suggest me to get EMS..and some suggest me to change LCP or extractor:confused:..coZ i dun really knw hw those will work..reading all those posts n comments i got really confuse coz non of yall talking bout aT wira wit vdo tb..guess its all bout mT wira vdo..i need help to mybe if u sifu's hv any idea of hw to reduce my Fc and maybe how to increase my pickup or hp or wtvr things that i can do wit it..for a smooth n comfortble cruze..tqvm:adore:
If you decide to go try EMS, let me know, I got one for sale :biggrin:
How high is high for your FC?
