- Joined
- Aug 18, 2006
- Messages
- 316
- Points
- 1,518
use it before,quick nice and have some pick up for certain only...
i have a questions, where would all these waste goes to?
All the gum & varnishes is dissolved in the fueling system.
No worried that it will clog your injectors.
You will be impressed after the live demo..
Car club is welcome..
I hope not getting stuck at the fuel injectors.![]()
you mention its either contamination or water. fuel injectors are part of the fueling system.
water is not an issue since it will just be converted to steam in the combustion chamber and comes out from the exhaust. considering it mixes with the fuel I doubt it'll cause rust for the internals of the fuel injector.
if its contamination - something solid, how can it be dissolved? for example, silica.
nah. It completely emulsifies anyway.
---------- Post added at 09:38 PM ---------- 6 hour anti-bump limit - Previous post was at 09:36 PM ----------
I can only assume you're not talking about sand in the combustion engine but in the fuel tank. Debris like sand won't dissolve in petrol I think so it probably will clog your injectors eventually. However the fuel system is relatively closed, I'd be curious to know how on earth sand got in in the first place.
How on earth? Well earth is composed of sand and dirt anyway.
http://www.i-car.com/pdf/advantage/online/2004/042604.pdf
http://www.carterfueldelivery.com/fuelpumps/_pdfs/support/TEC1622.pdf
its well documented, not rocket science :rolleyes:
Pay attention to petrol stations. The petroleum delivery trucks connects their hoses to the pipes that are near the ground and stores the fuel underground, not all petrol stations are squeaky clean like clean rooms. Can't be helped if contaminants do get it. Most petrol stations I see do have loose sand/earth on the ground.
Physical debris such as silica would probably sit on the bottom of the tank, but imagine if the delivery truck is delivery fuel to the underground tanks, gushing the sediments from the bottom while you're pumping fuel at the same.
Silica is only one example that I can think of, I don't know what other contaminants are there, I'm not an expert. I just know I don't want this stuff going to my fuel injectors. Looking at the simple demo, I do believe it works, and displacing water is good, my question is simply what happens to the contaminants such as silica? Telling me low chance of occurring doesn't explain what happens to it when mixed with fuel and this fuel system cleaner.
What are the effect of this cleaner to the fuel filter?, will the fuel filter be clogged afterwards and needing replacement?
yesterday juz pour it in n fuel up wif vpower.this mornin drove the car to work and the acceleration really affected badly like no power wif vpower. good sign i guess?
I've been thinking about this. I think sediments and such like this will get caught in the fuel filter. Having changed my filter recently and seeing how grainy it was lead to this conclusion. Let's discuss nonetheless.
Fuel filters will need to be changed no matter what. The emulsification of the water, petrol and all - I think it'll pass the filter easily and just get burnt in the combustion chamber.
---------- Post added at 07:35 PM ---------- 6 hour anti-bump limit - Previous post was at 07:33 PM ----------
That kinda sounds like my Myvi. The power wasn't really that much affected but my FC was bad. I think you should wait for this tank to clear off and try a new fill then see how. Btw, which Vpower is this? VPower green or VPower Racing?
Which leads me to wonder.. if your fuel filter gets dirtier, wouldn't it filter better -- and kill flow at the same time.
All filters have a micron rating.. anything below that rating won't get caught. That being said, I doubt it would kill the fuel injectors if its that minuscule.
Any improvement in performance.??.
