std inspira rims are 16j x 6.5j x off45....
std evo 8 or 9 rims, if im not mistaken 17j x 8j x off38
std evo 10, if not mistaken too would be 18j x 8.5j x off38
ex1: so if i change to evo8/9 std rims > the clearance from strut housing to the inside of the wheel will be [email protected] LESS & the outside edge of the wheel will EXTEND an extra [email protected]
ex2: so if i change to evo10 std rims > the clearance from strut housing to the inside of the wheel will be [email protected] LESS & the outside edge of the wheel will EXTEND an extra [email protected]
FYI, currently on work meister with these spec: 17j x 7.5j x off42.... looks fine on my car with 215/50 and never sangkut even with heavy load and full damper/coil compression... mathematically, the diff from std inspira rims would be> the clearance from strut housing to the inside of the wheel will be 10mm LESS & the outside edge of the wheel will EXTEND an extra 16mm
Good news bro...I have giv up my Ralliart rims as I tried to fix in & i cannot accept it without any wide body kit...hey all, just got my new wheels.... ce28 17x8 off40 paired to 235/45/17 csc3.... no problem sangkut or anything.... looks almost flushed.... almost.... so the diff from my previous wheels would be: 7.5j to 8 j, off42 to 40 = inner clearance 4mm lesser (+ another 3mm with tyres i assume), outside edge extended by 8mm (also +3mm with rubbers).....
so if u re taking the ralliart one, and u are migrating from std rims the diff would be: 6.5j to 9j, off45 to 30 = inner clearance 17mm lesser (+ another 3mm with tyres i assume), outside edge extended by 47mm (also +3mm with rubbers)..... NICE! evo spec!
Hi Everyone
Need your help to advise
im noob when come to wheels.
Check with you all
is this good for everyday drives?
i drive Inspira,
And would want to upgrade from 16" stock rims to CV3 17" inch rims pcd:114.3 offset 38
with tyre maxxis maz1 215/50/17,
is the tyre and and rims compatible?
or any you guys find that the offset higher close to 42 ~46 is better?
what is the consequences if using offset 38 ?
Hi All sifu,
Driving with Inspira with 215/50/17, plan to change aftermarket rim with the same 17" .what of the tolerance for the offset is the best actually? sorry I'm still quite confusing about the offset, worrying it could scrap the fender when loading.....while I'm no sure about the original 17" offset.
thks a lot.
Thanks a lot Brother! due rim kena and fixing has caused balancing issue in high spend.....
Yup. Found Lenso n Advanti quite nice in term of weight n quality! Lightweight increase up a bit n petrol as well; any comments for these two brands? Worry about the vossen since replica rim which made in Taiwan, even the designs all r catching eyes!
Advanti damn good for their price and weight! Go for them.
Don't go Replica. What for when u have value for money wheels to chose from.
Go for good set of rubbers as well.
