I have a problem with My Toyota SEG 4afe standard.
the problem is with the aircond
Scenario :
~ When i switch on the air cond, it will cold for some times, and then suddenly there is only air blowing and its not cool anymore
~ I need to switch off the engine and then after few moments-> switch on the key-> after few seconds-> start engine and switch on the air cond-> then only it will cool again..... Then after some times, same thing happen again. I've to repeat the same thing again.
Last time i send to air cond shop, the guy change cooling coil and valve and do some other things and fill up gas, but the same thing happen again after 1 week, send again to the same shop, he top up gas again and after few days, same thing happen again and send to other shop, but that guy say, he cannot see any problem cause it was normal on that time.. I did explain on the scenario but he said, he also don't know cause on that time it was ok...
Can someone help me to explain, what is the problem with this?
Any recommended shop for Air cond in Klang valley that i can get help?
Please recommend the best if you know...
Scenario :
R34 carbon monitor from Duke Racing japan
