yung
Want to ask who using adjustable cam pulley with stock can
And how many deg is set intake and ext
When I upgraded my cams to Evo 6 ones, I was being told by our expert Airtrek mechanic (Ah Wah from Kinrara Puchong) that using cam-pulley on stock Airtrek cam will not help. The degrees and lift is not high enough to benefit the advantage from the pulley. If you're on Evo cams, then yes. The degrees for evo-cam is 260 for inlet and 256 for exhaust.
Is there anyway to tell if evo 8 cams a genuine? Like number written on cams? Also is springs (evo or after market) recommended up evo 8 cam upgrade on airtrek, thanks
whatis the best adj cam pulley atr suggestion???
huhuhuhuuhhh....
Thanx
I can only find cam degrees for Evo ones. No info on Airtrek cams. The chart below which I found.
