External Radiator Fan Controller
v1ctorong
Dear All,
I just transplant JDM engine into my car. I found that my engine radiator fan only turn on around 95c (external water temp meter). The default ECU setting are basically made for Japan weather which i think its not mean for Malaysia.
When search for radiator fan controller, i found some selling online but looking for an experience foreman that sell and install the said controller for my car. Hope members here can help.
use the PIVOT Fan controller bro..it works for my 63t, same case like urs, 95C on water temp meter baru the fan jalan..
With pivot fan controller, i set it open at 90C, temp maintain at 90-93C during jam, on highway 88C..
Sorry to dampen your spirit, bro.
One Sunway sales rep said to me that PIVOT Fan controller is no longer in production (quite some time already actually). If the unit kong, or to claim warranty, replacement stock would not be possible.
Perhaps PIVOT could last long enuf.....if quality is good
There're still plenty of other brands besides the PIVOT..Nonit worry la bro..
pc fan?..not sure whether it can withstand the heat from the engine..
lesley...partly kidding..partly make sense :biggrin:
ehdrian..not the fan..but the controller..
example: http://www.frozencpu.com/products/15645/bus-308/G-VANS_30W_-_4_Channel_Aluminum_Rheobus_w_Multi_Color_Backlit_LED_-_Version_3_Ultra_Voltage_Edition_-_Black_GV2FC-5.html?tl=g47c17s817
check out the spec. voltage :smokin:
for someone who prefer manual toggle switch but dunnow where to get one....
http://www.frozencpu.com/products/7280/bus-138/Lamptron_Hummer_5_Port_Military_Switch_Baybus_-_Black.html?tl=g47c17s817
:thrasher:
what JDM engine u transplant into ur engine??..
Hi Shywalker , its a YRV Turbo @ K3veT
Hi ehdrian, was looking for PIVOT but ken yeang speak my concern.
thanks, it make sense to me.
:thrasher:
haha, i have PC fan controller too...but where to feed in the water temp sensor...hehehe.
victor....thats have to ask pc expert lorr.... i just giving some alternative thinking only :adore:
I see, i think lets eliminate this as i am looking for pure Automotive solution...:burnout:
---------- Post added at 03:49 PM ---------- 6 hour anti-bump limit - Previous post was at 03:46 PM ----------
Bro, may i ask where did you installed your fan controller?
ok more direct solution that i found... :adore:
http://www.mudah.my/Drift+performance+radiator+fan+controller-16913281.htm
if not mistaken the seller also a registered seller in zth...
Bro, may i ask where did you installed your fan controller?[/QUOTE]
i'm from penang actually, bought a used pivot f/c, got it installed and been using it for more than half year..no prob also..
A fren of mine driving myvi yrv turbo, bought a new set of pivot f/c from N1 racing because he's having the same prob like u..he's using alum rad also, now he got himself a low temp thermostat from D-Sport, prob settled..
Saw this as well, thanks for pointing out.
Thank you for enlighten me. So the low temp thermostat need to in my shopping list now. Also thank you to recommend the shop to me.
In order to benefit forumer, i will include the my experience in another topic created, after installation.
In order to benefit forumer, i will include the my experience in another topic created, after installation.[/QUOTE]
No prob bro, sharing is caring after all.
You can try installing Pivot f/c first, if it solves yr prob then u dun hv to waste money ade.
If it doesnt then only proceed with lower temp thermostat and alum radiator.
Yeah, share the before and after pivot f/c result with us.
Your suggestion is valid but i knew that my radiator is under perform. Where water temp wun drop when i on aircond during traffic jam under the hot afternoon sun. Both Fan and radiator need to change as the engine is now producing 3x more heat than the original kelisa engine :D. So will only consider to change low temp thermostat if condition wun improve.
http://www.mudah.my/HKS+Fan+Controller+Digital-17618105.htm
http://www.mudah.my/Variable+fan+controller+vfc+-16918478.htm
http://www.mudah.my/Drift+performance+radiator+fan+controller-16913281.htm?last=1
