Neo Campro CPS to Mivec 1.6 Boleh?
XlimShady
Hi guys, I recently discovered that a stock mivec 1.6 engine can actually produce over 170+hp.
Which is very impressive since that is about the figures you get with a compro turbo engine. I was planning all along to turbo my neo cps one day but then after discovering this I felt that if its is possible, it would be better to just tansplant a mivec 1.6 engine into my neo instead.
Furthermore it is possible to increase the Mivec 1.6 to 1.8 by changing the block if you ever want more power and turbocharging it will give you well over 200+ Hp. For now we'll just stick to a 1.6 Mivec conversion.
My questions are:
1. Is the engine mounting on the neo suitable for a mivec 1.6 engine?
2. Any reliability issues? And will the meters, and gauges on my still work properly?
3. Does the mivec 1.6 engine have very bad fuel consumption as claimed by some?
4. The cost of doing the whole job and also how much I can trade in my campro CPS engine for?
Those who have any info please do share here :wavey:
possible... can be done...
but personally id shove in a 4G93T instead... can always add in the mivec later on.
actually mivec can go up 240hp
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/384201_499743333387727_1881218965_n.jpg
block 4G93 CP piston + forged 4G93 rods + 4G93 crank
JUN 304 type 2
intake skunk2 ( no welding ) + racing air box
ekzoz 4-1 + Megaphone
RBP super single racing clutch
microtech lt-10s + x4 + msd twin tower
ACL race bearing
from : https://www.facebook.com/photo.php?...15229.100000561938109&type=1&relevant_count=1
sure that mivec 1.8 can reach over 200hp on wheels...
btw for the conversion mot much customizing needed..only "wiring combining" need some carefull attention.....other than that it was a perfect alternative instead of modding campro engine....
if u ask me i prefer the stock engine that is new...............................
Stock 4g92 mivec claims of 170bhp to me is pretty much overrated. Unless you managed to hybrid it with suitable 4g93 block. Even so to go any higher than 200whp with whatever mods with reliability in mind is pretty impossible....
Any recommended workshop to do this? I looking at Dori-dori but not sure if they provide this service.
not sure can recommend...because most i saw doing at normal workshop...perhaps u can try look in satria neo forum/segment to seek recommendation from the neo user.. :adore:
I'm interested in the guy that did the 240+hp mivec. Saw his FB.... looks like quite experienced in this field. Hehe
perhaps this is among the famous mivec tuner i heard....
Mal Auto Garage - Shah Alam, Malaysia - Perniagaan Tempatan | Facebook
CONTACT - MH TUNER
there is some discussion long time ago in http://www.zerotohundred.com/newforums/mitsubishi/359945-4g94-mivec.html
p/s:not advertising intended..just for info...
Thanks bro, really appreciate it. The guy i was talking about I smsed him, engine lantai 7.5-8k, workmanship 1.5k..... only bad thing is my engine trade in only 2k.... :bawling:
hello bro XlimShady, let me share some of my experience.... whether to convert or BOT or stay NA....
Objective
first is to consider what is your objective...
- drag?
- track & autokhanna?
- daily driven fun car with a bit more power and reliability?
OR...
- u want high HP or u want high torque?
once you decide what you want, then the mods will follow more naturally.....
Platform/chassis
then let us discuss your platform, a satria neo.......
FYI, it is not advisable for a satria neo to convert to 4G because of the difference in number of engine mounting, the campro in satria neo have only 2 engine mountings while the 4g92/4g93t have 3 mountings..... satria neo also missing the lower crossmember, unlike waja, gen2and persona, they have 3 mountings n the lower cross member, so its just plug n play.....
Conversion
yes u can sangkut the 4g engine but due to the short of one mounting, the rattle, vibration and movement of the more powerful 4G engine will definitely damage the handling of your neo (especially mivec that can rev up to 8.5k rpm in stock form), trust me u will hate your neo if you go this way.... but if u only wanna drag ur neo, then this conversion is the way to go because we can only use 4G series from CK5A or CM5A chassis or evo4-6.... but evo cant endorse anymore, so only few options.... of course u can ROJAK the 4G series like:
-get a mivec 1.6 and change the block to 1.8, so it becomes a mivec 1.8 OR
-get a gsr 1.8 and change the head to mivec, so it becomes a gsr 1.8 mivec..... YUMMY....
-also u can up the torque by using a 4g94 2.0 block but seriously, parts mmg rare n maintenance sucks............
-there is also a less powerful 4g93 GDI 1.8 NA or turbo but not worth the money spent.... (power is low n parts hard to get)
other points would be the age of these engines.... CK/CM chassis is at least 10-15 years already (since evo4 time), so the engine will also be as old as that... halfcut will set u back from rm 6k all the way to rm12k, then the cost of rebuilding and parts availability is kinda scarce...... meaning maintenance SUCKS! you also need to get it endorse.... bnyk kerja n bnyk duit..... but if u could source a good reputable tuner, it will be money well spend cos in stock std, the power is much2 higher that campro of all generation.....hehehe
BOT
an easy way and lately it is already save to BOT campro as long as u dont overboost the engine.... safe would mean that boost would be around 0.5-0.8psi max on std high compression internals.... this will net you HP around 170-190hp with quite great torque.... any higher than that be prepare to invest cos need to custom a lot of things.... do note that campro have tendency to fail on crank.... be it NA or BOT, many reported cases on campro failing on the crank.... patah terus n berkecai..... u can still daily drive BOT campro and it will still retain the superb neo handling and chassis capability cos u dont change or alter the mounting..... trust me it will be a fun car to drive!
Normal Aspiration
this is still the safest way to mod your neo and retain all the characteristics of the car.... campro sucks cos of the low rev torque dip, but in higher rpm range, it is still one of the modest engine around.... in the market now there are a lot of tuners coming up with perf parts for campro engine and proven on track/drag strip..... its just that the amount that u spend on an NA engine will not net as much power as a turbo engine.... if u spend rm30k on NA engine u maybe will net around 30hp max, but if u spend rm30k on a turbo engine, the power will be upped by at least 50hp.... but, NA easy to maintain n durable, turbo still not that hard to maintain but not as durable if u keep on redlining the engine....
i would suggest for your neo cps, keep it NA by:
- high comp pistons, or bore and use bigger pistons
- PnP head (stage 3)
- high cams and all related light pulleys available (crank, waterpump, adj cams)
- port match the intake, TB to the cams duration and degree
- open pod + CAI + fuel regulator + iridium plugs + bigger fuel rails + bigger core radiator + oil cooler + more powerful fuel pump
- properly tuned headers + free flow exhaust
- haltech platinum/sprint 500, if have extra cash go for 1000 (it can withstand higher temperature than 500 with more sensors)
- get a mivec gearbox with FD4.6 with or without LSD, or a cheaper option get exora manual GB.... it also have FD4.6
- exedy 3/4 puck with cover, get the japan one
- once all been done, get your engine fully balanced and blueprinted and then re-tune the haltech
these mods alone will allow your car to rev up to 8k rpm safely with usable power as low as 3k rpm (depend on setting) and you will get more torque n hp and retain all the nice handling, no need to endorse, parts senang dapat, etc etc
but always make sure you use a good lubrication which mostly expensive la (engine oil, gearbox oil, brake fluid, coolant, steering oil), and always buy ORIGINAL parts, never trust copycat parts..... pastu kalau dah siap semua get a good suspension setup via fully adjustable suspension, chassis bars, and upgrade your brake cos doesnt matter how powerful and how fast your ride, u still need to stop on time!
cheers and happy modding bro.....
Objective
- drag?
OR...
Platform/chassis
Conversion
BOT
Normal Aspiration
Wow, thanks for taking your time to write such a detailed explanation. Really appreciate it. =)
I'm still giving it some thought also.... since my goal is only about 180HP I might still go for BOT. My target is a fast street car, dun plan to track or drag. Street warrior only, can keep up with camry enough :rofl: Anything more than that next time change car already. But at the same time I like the high rev of NA..... so still need to give it some thought.
Now my mods are
1. 421 Straight flow exhaust (done my MFA from lowyat)
2. Iridium plugs
3. Open pod.
4. Zaptor VS
5. PnP throttle at Dori Dori
Latest service also done by dori dori.
Btw, I think they have cranks for campro engines already from the CFE engine which can be used on campro turbo. That might give the crank more reliability after BOT.
Hi, newbie here :)
wanna ask sumthing,if neo has less 1 mounting,can it be custom built and use it (safely) as 3rd mounting?
and lets say if,IF (somehow,somewhere) we can get the evo to be endorsed,is it gonna be a good long term,safe and reliable investment?
sorry if i'm asking somethg that may have bn asked before or redundant but im just looking for some clarification from all experienced bros and sifus here! thank you sir!
Anything you do in meddling with the mountings will be considered illegal in the eyes of JPJ. Even EK with K20 courtesy of Hassport mountings also deemed illegal (as of now I think)....
if the mounting was done properly, it can pass the puspakom without much trouble.....
because in jpj guidebook...it was stated for proton if transplant with mitsubishi more or less just a simple swap because same "mother" factory.....another example such as perodua with daihatsu engine (from similar model) also falls in the same category
Senarai buatan-buatan yang dikategorikan sebagai sama (klon)
PROTON a) MITSUBISHI
b) RENAULT (SAVY,WAJA 1.8)
c) CITROEN ( TIARA)
* penukaran enjin hendaklah dari model enjin yang sama varience dengan PROTON.Sebarang pengubahsuaian "Engine Mounting" adalah tidak dibenarkan sama sekali.
PERODUA DAIHATSU / TOYOTA
FORD MAZDA
PEUGOT CITROEN
HICOM ISUZU
