Guys, I just bought new tires for my ride..GY D5 for front & GY Asy2 for rear..I just wanna ask ur opinion since my ride is FR and i though i should run GY asy2 for rear since i need more grip on d back & also can swap front tire after used later since D5 is symmetry and didn't have inside/outside fixed..but my friend told me that i should use D5 at rear & Asy2 at front since asymmetric tire outside design for cornering which is contribute a lot for front wheel..
do u think i should change my setting r stay with mine now..sorry for my lack of knowledge..
Hmm probably should've just chosen the Asy2 for all 4 so it's easier for tire rotation. Anyway I'm also not sure which is better in your case. Your current setup may also be the right one since directional tires can be better in terms of wet grip and steering response. If you look at cars which use such combination of tires like the Lambo Murcielago, the directional tires are at the front while asymetric ones at the back. But of course each car is different so I guess maybe up to what is the current handling of your car and which one feels better for you. Best if you try both setup and decide since it's not too trouble some to rotate them anyway.
My car got problem..
