Wow where to get that bro zul? Arospeed brand?
good share bro, mind pm-ing where u bought it from n how much? many thanks!!
i believe cable type is longer lasting than the electronic type?
:proud:
iam more worroed about waking the neighbours je
actually....my dad worries on waking the JPJ guys only...so only used that exhaust about almost a year only...then revert to normal straight pipe to the rear........and the fender hole now welded shut and repainted to match....
this car still parked in the house...but need total rebuild on the body....![]()
having a short exhaust set up gives same effect as having different length extractor and types? ( 4-2-1 or 4-1 ). or will the short set-up just gives out different sound? hehe
thanks for the link, but mr.bill explained about the extractor length here. i was wondering about the whole set up, if the extractor-muffler ends at somewhere under the car (exiting under the door or something). normal set up vs short set up.
i think short exhaust setup produce less back pressure than a normal length setup
too bad its illegalso more acceleration right?too bad its illegal
You wake the neighbours, or you wake JPJ.. money can solve.. you wake the dead, money won't save you...
shorter piping can eliminate backpressure, improves acceleration, improve horsepower.but horsepower is not everything, a car with high horsepower does not necessarily can beat a car with lesser horsepower but with a higher torque in a straight line.
short piping, straight flow exhaust system are very good for pick up, but may affect the time of climbing to the top speed of the car. i use straight pipe, dyno'ed 140++hp (1.5 dohc), very brutal acceleration for 1500c NA engine (0-100 in 8 secs using rev speed meter) but after 150kmh, the car seems to lost its back pressure and its hard to reach the 200kmh mark.
Conclusion, good for pick up, but not top speed, improves hp but not torque.
(guys can brag with their horsepower figure, but winners do have high and steady torque)
:hmmmm:
