hehe... port the lower end, decrease fiction from the start...haha...:embarassed:
no la... its all about 'sciences'...:proud:that sounds a bit hamsap![]()
but now, u just port the outer part, haven't port the inside part.... mayb after port the inside will get better 'feel' ler..???:proud:unker, I both top and lower part is port.....only satisfied...if port only 1 place result not so satisfied.
...recently, i cleaned the throttle body by using carb cleaner...then, I found out your DIY....this would be my next DIY project...well, how long it takes to polish the inner TB ??....TitanRev san...two thumbs up......recently, i cleaned the throttle body by using carb cleaner...then, I found out your DIY....this would be my next DIY project...well, how long it takes to polish the inner TB ??....
sifuses & bros, if i'm not mistaken, the butterfly should fully closed when tb is cold but mine is not, is this a prob that needs to be solve??
What do you mean not fully closed? Is the flap spring pulling the butterfly closed or just half way or slightly open? If slightly it might be on purpose depending on what car you drive. It can't be completely sealed otherwise your car wouldn't be able to idle.
