Perdana V6 Community Forum *
thanks for the info. will contact him soon.
need advice here as my rvr engine recently got semput2 problem as like of misfiring but only happen when the engine is hot. when engine is cold one crank only it can start, but when hot it takes sometime to start. while driving also the same, the car just feel sluggish. get down from car and strong smell of fuel from the rear. change spark plug but still the same. Ill try to change the plug cable after this. anyone can loan theirs to me? any advice?:confused:
Didn't see this post earlier. May be your air flow sensor problem. Detecting the wrong amount of air going into the engine (because more air goes in during cold day compared to hot day). Try to open it and clean it with electronics contact cleaner. The AF sensor is located right after your air intake filters. It's a box.
Forget the ignition system, as it shouldnt be affected by air temperature.
have u contacted najib?
how's ur car?
not yet bro, busy lately. problem still there. thanks for the no. will tell him got the no from you.
---------- Post added at 12:52 PM ---------- 6 hour anti-bump limit - Previous post was at 12:45 PM ----------
my af sensor code is 609. is it correct for rvr auto? can i use wd40 to clean it? just spray at the honey comb mesh?
No, dont use WD40. It must be a clean solution like cleaning alcohol or contact cleaner. You need to remove the sensor to clean the sensing wire inside (I haven't opened the Perdana's one before so am not 100% sure how it looks like inside).
Hi Bro's has anyone used SHOJI or PRORIDE brand disc rotors for eterna ? they are crossed drilled and slotted and both around 400-450 for evo 3 size.
My rotors makan so brake pad wear is uneven and noisy. Don't prefer skimming.
Project MU and Hypermax are 1k++.... way too expensive.
Any other brands can you guys recommend ?
Thanks.
Hi all,
Got a few question to ask,
1) RVR auto can transplant into perdana v6 chassis without modification to the gearbox mounting?
2) anyone using RVR? how's the FC compare to 6A12T.
Thanks
**should be no problem. try asking neurone he is using RVR auto
**FC depends on how heavy your right foot is..hehe....definately 6a12tt manual FC much more better than RVR on highways,
in fact even better compared to 6a12 n/a auto
hmm, my previous 6a12tt full tank can clock around 350-420km only. hopefully RVR won't let me down.
Hi all,
Thanks
1. yep. no mod on the mounting points but rear mounting 'bracket' need to mod/custom. i think can find an OEM Mitsubishi bracket but i dono from what car. cant find, so i custom my rear bracket.
2. my 4G63T RVR auto FC is just like my previous 6A12 Perdana auto, maybe a tiny bit higher FC, tiny.. also depends on my right foot.. i always calculate my FC. from my calculations, i get about 7.5-8km/L (town) and 10.5-11.5km/L (hiway). look here http://www.fuelly.com/driver/neuroone/perdana for my average FC.
if wanna compare 4G63T RVR auto with 6A12T Galant/Eterna auto, then it will more or less similar. if u compare both engines with auto or manual, then manual will surely win in FC.
Hi Guys. Need some help and advice. I've been running on my v6tt-rs for more than 3 years now. First 2 years it was on auto GB. After twice failing me, i change it to a manual GB. The car now runs on a original eterna NA manual GB (forgot the code) after few months running on this GB (with brand new clutch), the clutch starts slipping. I've posted this issue on another thread and bro Danz answered my questions. My issue is now, if anyone here can recommend me a good and reliable workshop somewhere in setapak/sentul/batu caves?
I am a former v-sixers rep in malacca, moved to kl bout 6 years ago, still using this car once a while (when having the urge to be a bad boy) :biggrin:, won't be selling it soon coz love this car too much. hehe. any feedbacks are very much welcomed. thanks/salam.
welkam bck bro.....anyways the code plays an important role, just make sure its 312 or 332. not 222 or 232 if not u will have 5th gear syncro problems in the future.
your clutch slips at wat rpm? mine also slips....if u bought your 9" daikin/exedy clutch @ spare part shop then thats the culprit. same case as me.
not sure bout workshop recomendation. try asking NeurOne.....
Thanks bro Danz...i am sure the exedy clucth were bought somewhere at a spare part shop coz the mechanic himself told me...:banghead:
Btw my GB is 312. Thanks bro...u really helped a lot. Hopefully someone can advise a proper workshop fr me to change the clutch:)
Sent from my GT-I9300 using Xparent Red Tapatalk 2
long time since i've been here.. just googling out and i am very interested in having an external transmission filter for my v6.. but if anyone could help me to find this kind of filter base,
but the one that can be found in mudah is this type.
http://img.rnudah.com/images/20/2073954447.jpg
as u can see, it uses a larger hoses because it is intended for the engine oil.
as for our GB, it uses a smaller hoses. i need to have the filter base as in the first pic top so that it will not affect the flow rate and the pressure of the atf from GB, radiator, and to the atf cooler.
anyone had any idea where can i find this type of filter base? i want to diy this filter as it seems so easy and fun to do. plus, it will be easier for me to change the filter, other than dropping off the pan. thanks in advance!
worth trying proride brand....
bro Danz, it is worth it to buy 2008 V6 than i just upgrade the GB from auto to manual? available or not the GB? planning to get 1 but don't like drive in auto trans.i love the v6 engine.so i manage to get 1 done want to do engine transplant.
i guess u need at least semi or full racing clutch 4-6puck. std ones cant grip.
im sure around your neighbourhood has many car workshops.....i suggest u find one near your hse so easy for u to follow up on your car.
---------- Post added at 09:03 PM ---------- 6 hour anti-bump limit - Previous post was at 09:01 PM ----------
if u plan to keep your ride std. then go for 08 model with manual tranny. but if u wanna transplant the engine is not worth it, better find one that already converted & fully moded. but most of them below 2000 model.
---------- Post added at 09:06 PM ---------- 6 hour anti-bump limit - Previous post was at 09:03 PM ----------
im also looking for it for my engine oil filter relocation. try asking andy from rev performance in sunway. he might have it.
try survey for manual tranny but not found.all selling auto.below 2000 too old already.:biggrin: just wanna to mode the tranny only.do some random survey they quote me around 4k.think i might hold my interest for a while.slowly survey till get manual tranny.
thank you danz.. i might be searching for that type of plug in a hardware store as well hihi :hmmmm:
