RWD can cause the car to have more oversteer and AWD make the car to have more understeer when coming to corners
Even Nissan GTR R33 & R34 in Japan GT is modified to RWD with wider tire in the front at is 330mm while car like Enzo FXX front tire is only 255mm or 245mm
But RWD are more likely to spin in corner if throttle is applied, will be harder to turn a AWD as will cause understeer
The reason AWD doesn't spin out that easily is because some percentage of power is transferred to front wheel while RWD have 100% power only on the rear wheel
Such car like AWD = Skyline GTR, how to make this type of cars turn well (more oversteer), how should the suspension be setup on front and rear
Pls advise on suspension setting of such AWD or is it better to have RWD
