Bo SEG
hye there...
here i need some advice from all who know something about 7age 20v project...
i was built 7age 20v on blacktop.....
spec..
cp 82mm piston
7a-fe block bore 82mm
7a duratech con rod
king conrod bearing
stock 20v bt head + stock Cam + stock cam gears
4age 16v timing belt
0.8mm trd metal head gasket
7a 212mm flywheel
4age 20v 6 speed gearbox
clutch cover exedy racing with trinity clutch disc
tom's trumpet
e manage blue ecu
1 jz fuel pump
work fuel regulator
ngk r 09 plug cable
iridium tough vk 20 plug
but now after dyno...i only got 140ps..
the tuner said i must reduce the compression to get more hp..
he said my engine got to much of knocking...
he tell me to put around 2mm head gasket to reduce the compression..
too high compression will reduce the hp coz of too much of knocking...
so now he retard the firing(if not mistaken)...
and my engine dont have power that it deserve...
is that true???..
can this spec produce lot hp?
is there have another spec that suit for 7age setup????
i want to put 288 deg 9.2 lift for my engine...
but i want to settle this problem 1st to see the stock 7age 20v could make...
spec..
cp 82mm piston
7a duratech con rod
king conrod bearing
7a 212mm flywheel
tom's trumpet
e manage blue ecu
1 jz fuel pump
work fuel regulator
ngk r 09 plug cable
is that true???..
I wonder if anyone out here can advise on the...
