Should i BOT or upgrade from 4g91 to 4g93 block
iswara204
Hi guys, im struck by dilemma of the mentioned title, Should i BOT my 4g91 or upgrade 4g91 to 4g93 engine block.
I have been on 4g91 for years and its time to look into some upgrade and i came across the options. But im in a dilemma trying to decide what to go for. My concern here would be budget, like any other project :D and ofcourse the HP gain to be compared aswell.
Im keeping my budget about 3k, max 3.5k.
I did some homework and managed to come up with some initial price budgetary for the parts needed.
4g91 BOT
TD04L : 400-500 maybe need to service, so add another 200 for the service/repair kit
Exhaust header (Banana) : 500-600
390cc GSR injectors : 200-300
Metal casket: 150-200
intercooler: 300-400
intercooler piping: 500 ( just an estimation, if cheaper the better la)
emanage/safc2/neo: below 1000
Overall( i took the high side): RM4200..aiyaaa
4g91 to 4g93
4g93 block : 750
4g93 timing belt: 200-250
240cc injectors: 200-300
4g93 air flow sensor and ECU : 1000
Tbody and intake manifold: 500
Overall( i took the high side): RM2800..ehmmm
Please advise or add on if i have missed anything or correct my pricing if its not right? What would you guys go for you have this options?
As an owner of someone who did a NA->Turbo swap. I would suggest the 4G93 block.
Easier to service, easier to maintain.
Doing aftermarket turbo, if you do it cheap, or something go wrong. Boom. Then costs more money to fix.
---------- Post added at 04:49 PM ---------- 6 hour anti-bump limit - Previous post was at 04:48 PM ----------
You may need more $$$ for BOT. Probably bigger injectors and if you have not improved on your brakes and suspension that is another set back on your wallet....:hmmmm:
Hi bro, thx for the I input bro. I'm actually having the similar thoughts as well. What if it breakdown, more $$ to repair. But with many folks successfully bot'ed, with proper recipe, I don't have to pay a price for error! Ehmm..
---------- Post added at 07:21 PM ---------- 6 hour anti-bump limit - Previous post was at 07:19 PM ----------
That part is covered for now. Brakes and suspension is at it's best! Hehe
Oh! if turbo, exhaust system needs change too.....
a 91 isnt dat far off then a 93's performance,id tune dat 91 up rather den changing it to an 1800,which cant be nearly be compared to a charged 91.of course, i will always suggest u go d boosted way
I'm running on 2.0 inch at the moment. Feel sluggish in the 91 setting. Feels like 1.8 inch is the best pipe size for 91. But if BOT, I think 2.0 inch should be ok.
---------- Post added at 07:57 AM ---------- 6 hour anti-bump limit - Previous post was at 07:41 AM ----------
91 and 93 not much power difference? Definitely the hp gain is significant bro. Ehm, and the only set back would be 1.5 gbox compared to the 1.8 gbox which has a better gear ratio. My concern here is budget, even without workmanship, it's over my budget. *holding my head
Oh! Never expected your 4G91 to be running on 2" pipes...:biggrin:
Depends on what you want. Lower cost lower gain. BOT will cost more but HP gain is different ball game....:smokin:
Yalah bro, i dont know what was i thinking when i was the pipe shop!! *banging my head on the wall
But its a NO NO for 91's to go on 2.0 inch! learning it the hard way! i didnt do homework on that!
Yup. sometimes learn the hard way. So now you ask first in the forum for some answers....:biggrin:
mine was running a 2inch zorst,acceleration was crisp jer.. are u running a striaght pipe ke?
4g91 BOT
4g91 to 4g93
4g93 block : 750
Hi.....
I have a wira aeroback which i have converted to 4g93t...
And in it i did
1)fully forged cp pistons
2)Duratec conrods
3)balanced engine as well as crankshaft and whole works....
4)td05 turbo boosting at 1.2bar,40mm turbosmart wastegate
I have an emanaged blue tuned by GT Auto....
Thought of selling the car...PM me if u have thought bout it....
Better than doing BOT,although slightly pricey...but i m sure the car more reliable than BOT
Hehehe
a charged project can be reliable if u know what u r doing.. and dis isnt a place to sell anything,admin?
a straight pipe for d 91 isnt a good way to harness its power fyi, get a proper zorst system, u will definitely feel d difference
its not that cheap, trust me...there will be overhead expenses involved...if u want to make a reliable engine, u must overhaul the engine 1st...an ageing block like 4g93 needs to be overhauled...I've done a 4g91 to 4g93 conversion, block rm750, injectors rm200, I am using the 4g91 wiring n ecu but using e-manage, and then the overhaul and transplant labour about rm1.6k...I've spent more than rm5k upgrading, for a reliable engine...
syimir,hence y i suggested y tuning d 91 is best+proper zorst system
how much for a good zorst system?bfore converting to 4g93, I've tuned my 4g91...its a good engine, ecu rechip to 8k rpm, e-manage, high cam n bla bla bla...dyno was 130whp ++ which translates to more than 170hp..but still tuning an engine for good power still consumes lots of money.far exceeding the rm3k mark.
so my advice is, save a sufficient amount of money first or buy parts by parts if u want to tune ur 4g91, or upgrading to 4g93.
