Hey PocRoc,
Do you think I can use this to spray?
http://i01.i.aliimg.com/wsphoto/v0/712017693/-font-b-Car-b-font-watering-can-font-b-sprayer-b-font-water-bottle-watering.jpg
Why you need a sprayer if you use aerosol can?:hmmmm:
Hey PocRoc,
Izso i think the spray pattern wouldnt be the same as the spray can. but that being said if water is pressurised inside the spray bottle it will will give the mist that is similar to spray can mist (to my naked eye). I'm not sure how thick is the dip + xylene mix, if it is thicker it will be a problem to get thru the spray nozzle.
i think he wants a color that dont have can type in malaysia. like i wanted yellow
I want to by Xylene, mix with the dip (can variant) and spray on my own. The aerosol spray can will be for other smaller projects. If I can use this pressure pump spray then it'll be worthwhile since I can't afford a air compressor.
I think I'm going to try it. Worst case scenario is it won't work and spoils a RM15 pressure spray. And waste a bit of dip.
Just spray my trunk lid in Grey... and yesterday sent it for car wash with high pressure jet, the plasti dip still intact
Where you would like to dip with Yellow? Interesting...
If you need more than a aerosol can, then you let me know
I have black, blue, brown, yellow, Green, white, fl. green, gray and fl. yellow in gallon
Xylene is not the right agent to dilute with the Plasti Dip. The recommended thinners are Toluene (is banned) or VM&P Naptha.
The pressure from the sprayer is insufficient to push out the plasti dip, eventually it will clog the nozzle.
Not a good idea bro, the pressure in that spray wont be consistent if u spray water out of it eventually the amount of spray will lessen throughout the process then I dunno how many times u need to pump that thingHey PocRoc,
But already advised by a friend not to use microfibre.
nothing like trying out
Not just the colour bro, spraying whole car using spray can is not gonna be easy and the results
wont be as good as using a Pressure Spray Gun.
Microfiber cloth is not an good idea to wipe on the plasti dip. I use compressed air at the car wash to blow the water away
I didn't buy a lot but just few colours to try it out.:aetsch:
---------- Post added at 10:16 AM ---------- 6 hour anti-bump limit - Previous post was at 10:11 AM ----------
Is true! They recommended HVLP spray gun. If possible get airless.
Every coat you spray make sure is WET and the surrounding is DUST FREE
