Proton Perdana 2.0 V6 Twin Turbo
Make: Proton
Model: Perdana SEI
Converted: Mitsubishi ETERNA 2.0 V6 Twin Turbo
Year Made: 1997
Engine:
2.0CC V6 Twin Turbo Intercooler
Evolution III RS Intercooler with SAMCO Sport blue hoses
HKS SSQV 2 Blow off Valve (Made in Thailand)
Customized turbo down/screamer/waste pipe (1”piping)
Original TD02L (blue tag) Twin turbines serviced @ Tong Turbo 2007
Original HKS open pod air filter
Customized Blow off valve piping’s with SAMCO hoses
Head ported & polished Dec 2009
New battery Century Marathoner NS60 Oct 2011
RVR RS Turbo radiator for better cooling efficiency – only Toyota coolant used
High speed radiator fan motor.
Manual boost regulator/controller (tulang ikan)
Evolution I gear differentials for drag racing/sprint (Non LSD)
** shorter gear ratios.
**previously using Mivec V6 6A12TT Code : 332 gearbox with LSD
VR4 RS (C Shift) Short thrower/shifter modified to fit in Perdana.
Exedy (Daikin) std clutch set. 9”
Skimmed flywheel
FGK Fujitsubo CE9A Evo 3 Exhaust
Stainless Steel 3”-3.5” Customized exhaust piping
Japan Pivot Raizin blue Voltage Stabilizer
Customized aftermarket BRISK precision cutting aluminum crank pulley
Precision cutting/grind of crankshaft for better performance
DENSO IK20 Iridium Spark Plugs – lasts up to100k kms
BOSCH Super Sports 8mm Racing Plug Cables
ZerOne Grounding Wires
Only using CASTROL Magnatec Semi Synthetic Engine Oil – changed every 5-6k kms
Galant VRG original Strut Bar
SPAC 0.8 bar radiator cap with pressure release button
**Fully rebuild engine blueprinting, port & polish, rebored intakes on Feb 2010, costs RM5k++ for parts only.
Exterior
Front original PV6 1st version bumper
OEM front bumper brackets
Rear original PV6 1st version bumper
Honda SV4 rear side markers
Original PV6 side skirting
Rear aftermarket smoked lamps
ETERNA rear boot reflector
ETERNA boot Spoiler
Ganador style side mirrors with signal light
Lifted/jacked front bonnet for better cooling efficiency
PIAA wipers
Fixed extendable radio antenna up to 6 feet
Aftermarket window visor – Medium size
Aftermarket CAI – Cold Air Intake
ETERNA Samurai front radiator grill
Interior
Black face meter 180km/h
ETERNA Coin holder & button switch
MOMO Subaru Steering with red stitches
MOMO Gear knob cover
SSCUS Semi Bucket seats (EVO V) style, Titanium color
NISMO Gear knob
SSCUS bracket seats
ETERNA digital air cond panel
Universal Mini Turbo Timer
SARD Racing Exhaust temperature meter
PIVOT Shift Lamp @ 7k RPM
HKS Racing Turbo Boost meter
Panasonic single DIN CD Player with remote control
All windows black double layered tinted to 70%
WILLANS 4Point Racing harness with quick release
ETERNA driver window control panel
Pivot VCAPA Voltage Stabilizer & Battery Strength reading
Rims/Tires/Suspension
P1 Buddyclub (Made in Japan), White
114.3 x 4 holes – rare
Front : 8JJ / Offset 32 (can clear 6pot) Tires : 225/45/17 Federal 595 Evo
Rear : 9JJ / Offset 37 Tires : 245/45/17 Bridgestone Potenza RE050 RFT
Hotbits adjustable high/low
Newly services Feb 2011 HOTBITS high/low adjustable suspension system
ETERNA Twin pot braking system – just serviced
Rear camber adjusted to -1.3 degrees to avoid over steer.
Front camber adjusted to -0.8 degrees to avoid over steer.
*precision measurements.
Cross Drilled disk brakes for better cooling efficiency
RMSOLD
Pls call Danz 0182320098
Location : Persiaran USJ (Off Jalan Batu 3 Lama, Shah Alam)
Engine Rebuild in 2010.
Car only used strictly on weekends only.
2. I’m the 4th owner
3. Car well taken car off, but sadly need to upgrade to MPV or EXECUTIVE car as family getting bigger
4. All engine parts are bought brand new, only those hard to find parts are sourced from half cut shops
5. Need a full respray on car
6. Cash buyer only.
7. All items above + servicing + maintenance spent RM40k++
8. Very careful owner & fussy when it comes to changing parts.
9. Cheap & reliable new parts supplier will be provided – home/office delivery
10. Car endorsed by JPJ.
11. Just add on a 0.8-1.2 metal gasket & 4-6 pucks racing clutch & able to eat evo1-3 for lunch, SR20 for dinner & if lucky RB20 for supper haha….cos clutch slips at high boost. Metal gasket to ensure engine does not blow.
Make: Proton
Model: Perdana SEI
Year Made: 1997
Engine:
Skimmed flywheel
Exterior
ETERNA boot Spoiler
PIAA wipers
Interior
NISMO Gear knob
SSCUS bracket seats
RMSOLD
6. Cash buyer only.
:aetsch:
Looking at the things you have on this car you could've bought that Evo cash!
