R.D'Raol
Well, for me rim design are all personal whether this looks better or that. Rim design also have to match the car you are fitting to. Sometimes the rims looks nice by itself, but when match to the car it dos not stand out.
To have a rim that looks BIG, then the spokes have to reach the edge of the rims. Both the CE28 and TE37 curves and joins inside rather then reach the end. Of course both design have pros and cons. Rims spoke curves in you can have rims with lips coming out, but this can dent easily. Spokes that reaches the rim edge are stronger on this, but do not have the lips.
9.5J can fit 245/40R18
10J better 255/40R18, you want garang some more the 265/35R18, 265/40R18, even 275/35R18...![]()
Okay, I will answer this based on your current tyre size of 245/40R18.255/40R18 which is 1.23% bigger in diameter is good fit for 9.5JJ rims265/4R18 is also good fit for 10JJ rims, however overall diameter is bigger by 2.4% therefore you have to check whether your wheel arch have enough space to fit this size tyre.If you fit 275/35R18 the sidewall actually is about the same as the 245/40R18 tyres.*245 x 40% = 98mm275 x 35% = 96.25mm therefore sidewall is lower by 1.75mm only, but tyres are wider by 30mm, therefore overall the sidewall looks thinner. Overall diameter is very close, smaller by 0.55% only, but again have to check whether the additional 30mm tyre width can be fitted in or not.
Sifu.....will this b the same for 16 inch rim also???
:rolleyes:
