4G63 EVO123 oil filter housing
gIGoN
guys,
i need to replace the oil filter housing (the housing which has oil filter / oil press sensor / oil cooler hose at the bottom). Where can i get the gasket for that...is it easily available in sparepart shop? any of you know where to get it please let me know.
how it looks like ah?
try asking andy from rev performance.
Its something like this
if its a small leak jer,use a good gum gasket to stop the leak,i dont see the need to change the oil filter adapter
it's not a leak...the thread on the oil sensor hole is totally trashed..i can't even put any bolt or anything unless i re thread it....might as well jsut change the whole thing to be safe as i need to hook up my new sensors....
dats sum trouble jugek tu,get a good replacement unit den.. i remember seeing new ones on millennium motorsports asia's shelf the last time i was there.
i got the replacement....i need the gasket dunno where to buy it....been to a few spare part shop in sunway.....end up getting 'gasket ketuk' but if anyone knows where can get the gasket is even better....
hi guys, if i use gasket 'ketuk' for the oil filter housing, should i use the gam gasket? the gasket is good enuff to prevent oil leaking?
