How much for the rotors? And if you don't mind, where did you get it done?
Rm160.
Gahh.. I guess that's the difference between a big expensive car vs my Wira. I found and bought the Bendix Metal King Titinium for my rears yesterday for RM80.
Last time I bought the BMK Titanium for my front was RM100 only.....few years back. Anyway the Trestor from same manufacturer, I got for RM120 last year....![]()
Haha bro, 6UE5t upgrading his setup at sunway kakimotor. The price of the stuffs also need to include heavy rental as well. I never change spare parts at sunway area due to mostly alot of parts are overpice. Last time quote me Osram nightbreaker H4 need RM160 and I was walk away and found same at S'ban area just only cost me RM90 included installation.
Hmm the thing is the sucky std Toyota rear pads for my car is already like rm200! So rm160 is already cheaper. I've aksed some other sellers too and roughly gave me about the same price, just maybe rm10 difference.
Yup, OEM pads are lousy and are more expensive. My colleague's Accord I think he mention OE pads around RM400 so he also fitted Project MU pads....![]()
Haha, you are a hunter 6UE5t. Can get cheaper price around sunway + it's kakimotor. Wa, you almost burned 2k on the brake system, so satisfied with your new brake system?
Not almost, it's already OVER rm2K!
So far yeah, satisfied. Will update later once I can test it with more force/hard braking.
Slotted and cross drilled rotors just allow you to brake without worry about fading (not as worried, not completely don't have fade), awesome pads let you brake harder but paired with slotted rotors your pads will wear out faster. With the steel braided hoses your pedal pressure should be very linear and controllable.
If you're talking about braking harder and faster - probably yes for the harder but not necessarily faster. Your car has ABS and EBD so you'll still probably stop the same distance but you'll be able stop the car at higher speeds in comparison.
I think. :hmmmm:
Hahaha yeah, with that much spent, it has to give a good improvement!
Anyway I'm happy with the improvement especially the initial bite, it gives a lot more confidence. I think it should allow me to brake faster because now I can achieve more braking power with less pedal travel, while previously I have to press much deeper to get meaningful braking force. I think you're right though that once the brakes lock up, the ABS should take over and from then on the distance could be about the same. But maybe now is much easier to lock up due to better initial bite.
) Hahaha yeah, with that much spent, it has to give a good improvement!
It's a lot harder to trigger the ABS than what most people think. I've tried a dozen times on my Myvi and have only ever successfully done it 1 time in a controlled environment. The other times were real emergency situations (about 4 times..)
Anyway, I wish I had that kinda dough to blow on a car. I want bigger calipers.
Oh hey, 6uest - you should consider swapping out your brake oil (flush) with DOT5.1 (assuming your car isn't on DOT5) especially from those reputable brands like Ferodo and Motul. To me the brake oil made a helluva difference when I was *driving aggressively* down Genting (caveat - not racing). Even with the same brake pads for some reason the oil helped reduce the super spongy pedal feel as a result of overheating. Not that you'll be cooking your brakes often but hey, overkill is better than regretting.
6UE5t, your rotor is slotted 1 right? Is it noisier than previous setup when you apply brake?
Hmm to trigger ABS you just need to really stomp on the pedal as in during emergency braking. I've successfully done it several times on several different cars. In the wet it's very easy to trigger it though.
No, I just use regular dot 4 for now. Maybe later will try when comes time to reflush it again. Thx for the suggestion.
So far still no noticable noise yet when applying the brake. Just when I release it from stop, then got just a bit 'ngek' sound which previously not heard, but that's all.
