Hi all,
As per title, im looking for a good quality 2nd hand 2ch amp to power up my sub. Currently im using 2 kicker sub 12'' rated 150rms each. Preferable for middle range stuff (eg Mohawk Cyrstal,Kicker,MTX etc). Price will be consider. Pls feel free to share yours and dun forget to attached some picture of them.
Another confusion, what's does the below spec mean. Really dun get it. How many chanl actlly does it has : :hmmmm:
• RMS Power Rating (14.4V):
◦4 ohms: 110 watts x 2 chan.
◦3 ohms: 135 watts x 2 chan.
◦2 ohms: 180 watts x 2 chan.
• Bridged Power Rating (14.4V):
◦Bridged, 8 ohms: 220 watts x 1 chan.
◦Bridged, 6 ohms: 270 watts x 1 chan.
◦Bridged, 4 ohms: 360 watts x 1 chan.
• 2 x 20A Fuse
• Pulse Width Modulated MOSFET power supply
• LED power (green) and protect (red) indicators
• Variable Bass Boost (0 to +9 dB bass boost at 50 Hz)
• Soft Start Turn-on
• 2/1 channel operation
• Speaker-level inputs with signal sensing for automatic turn-on
• Preamp RCA outputs to daisy chain multiple amps
• 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
• Heavy duty aluminum alloy heatsink for extreme heat dissipation
• Silver-plated RCA level inputs
• Silver-plated screw terminals
• Input sensitivity: ◦Low level: 200mV-4V
◦High level: 2V-10V
• Variable high-pass filter (50-500 Hz, 12 dB/octave)
• Variable low-pass filter (50-500 Hz, 12 dB/octave)
• Frequency response: 10-35,000 Hz
• Dimensions: 12-13/16"L x 9-5/8"W x 2-3/16"H
Pls share you expert view on this
• 2 x 20A Fuse
◦High level: 2V-10V
