The only real way to test which fuel is better is to do controlled test & dyno runs of each fuels on different vehicles...If not, it's just a matter of opinion...there are alot of factors to take into account....:hmmmm:
although u r true iszo,but it can be made as a reference. i dont think there are much difference between engines with similar spec,so will d outcome will not differ much
there's also another consideration - not all petrol station petrol quality is necessarily the same. Have to assume the station owner is honest and only uses one supplier and also another thing is that he keeps his underground storage tanks clean and changes it every 3 years (I think that's the industry standard age)
Wah lahad datu?
The exhaust bup bup bup isn't engine knocking sound. Engine knocking sound is something like pinging..like two flat flexible plate tapping each other...klank klank klank. If you wana have a feel of how it sounds, try going up hill, then put high gear and press the pedal. You hear that sound for sure.
I think ur engine has no problem with RON95. But as per mentioned before, the safest is by looking at the engine spec and manual book for clearer statement.
My car has that klank klank sound. It happens when i accelerate at higher gears, usually 5th gear. For example, at 60km/h on 5th gear, I accelerate and I hear that sound. And when i'm travelling at high speed say 150km/h, I also hear that.
Does this mean that my engine is knocking? And is that ok or bad? Damn I'm worried now.
When u say not like metallic sound, do u mean that klank klank sound is ok? It means that it's not knocking?
I noticed another thing, usually when i pump Esso Ron 95, as I'm driving out of the station, it will be ok. Then when I tekan, it's like not accelerating at all. But then suddenly it will jerk like that. It this what u mean by misfiring?
I'm sorry but I'm not too familiar with words like misfiring and all. I can only imagine what its like but I don't know if it is what it is exactly until I feel it.
If so, my car is misfiring and all, what do I need to do now?
The klakklakklak sound you get when you are shifting gear and the car doesn't really move is pinging, high revving and you hear knocking sound, that's knocking/pinging (same thing).
Misfiring is when you're accelerating and your engine is choking, feels very jerky and just feels like the car isn't firing on all cylinders.
Ok. My car is moving fine when I'm shifting. When high revving, will the car also feel like its not really moving?
This misfiring thing happens only when I fill my car with Esso Ron 95. It really feels like the engine is choking. But it only happens when I tekan. Slowly accelerate no choking or jerking. Is it misfiring? Usually this misfiring thing happens all the time or occasionally like what I'm facing?
Ah, I think you are the rare few who owns a high performance honda with a stock ecu. The feel you described is very similar to the ECu pulling ignition timing after it encounter knock
What about other brand Ron 95?
The explanation quite similar to my VR using Ron 95 last time. Slow speed below 4k RPM no problem but if accelerate cannot go pass 4.5k RPM. Hesitation, refuse to go to higher revs, jerks and so on. This means it is knocking....![]()
But I'm using s300? It was dyno tuned. Could it be because it was not properly tuned?
Other brand ron95 no problem. In fact my car has always been using ron95. The problem is not similar to yours. I can slowly accelerate till 8k or 9k. But if I pedal to the floor quickly then it chokes.
a 4g93 twin cam.
