McGard Tuner Wheel Lock Nut
fitri_thiang86
Worry About Your Expensive Rims or Rare Rims Being Stolen?
Now days even stock alloy rims being stolen everyday....every second our expensive or rare rims are in the eyes of the thief....the solution is MCGARD!!!!
McGard Tuner Wheel Lock Nut is a no-compromise design engineered to fit into close tolerance lug hole recesses in Tuner Style wheels or wheels with very small lug nut holes. Weight matched to our SplineDrive Lug Nuts. For alloy wheels only, not for use on steel wheels. Tuner series is the high end product for Cone Series Compare to other seller selling low end product for the price of the high end series.
Items are complete with the below specs;
1.24" Overall Length
M12 x 1.5 Thread Size
13/16" Hex Size
Cone Seat Style Wheel Locks
Set of 4 Locks and 1 Key
Can be used mostly all cars such as honda, mitsubishi, proton, perodua, toyota using the above thread size except nisssan & subaru...or you guys could go to Home - McGard: Innovative Security Products to check whether your car can used this Lock Nut Thread Size. The diifferent between McGard and others brand such as Rays is that every Key Lock is not the same...
Stock Are Limited as item need to be import from USA...Interested sms me at 012-2235339...COD at TESCO AMPANG, postage can be arrange...
blh bro...pe link nie...
http://www.mcgard.com/component/hikashop/product/874-chrome-tuner-style-cone-seat-wheel-lock-set-m12-x-15-thread-size-set-of-4-locks-and-1-key?Itemid=0
Setiap McGard punya Lock Key berbeza antara satu sama lain...
BUMP...
Black anodized per 16 biji tuk myvi baper rm..?
in stock ada McGard Lock Nut je bro...ada 4 biji...pakai satu kat setiap rim...kalau nk model lain McGard blh order...
---------- Post added at 10:46 AM ---------- 6 hour anti-bump limit - Previous post was at 07:53 AM ----------
Bump....
Every McGard has its own special Lock Key compare brand like Rays or Tpi or many more which use a same Lock Key....
BUMP....
Do you have Chrome Cone Seat Wheel Lock Set (M12 x 1.5 Thread Size) - Set of 4 Locks and 1 Key Part No. 24157 or Cone Seat- Under Hub Cap Wheel Lock Set (M12 x 1.5 Thread Size) - Set of 4 Locks and 1 Key Part No. 24012 ?
Whats the different compare to the one you selling ? I saw the lock key is 'long' ?
I dont have the one you are requesting...the different between mine and the one you wanted is the length and mine can be use in aftermarket rims, Cone Seat- Under Hub Cap Wheel Lock Set is for people using bbs rim which have center rim cover...Chrome Cone Seat Wheel Lock Set cant be used on some after market rim such RP01, due to the wheel lock is broad.
Hope my explanation is sufficient...hehehe...
