The general rule is the lower you go, the harder you need to set the absorbers. So set it harder la. Or higher. Either way.
How many clicks you can find out yourself mah, click soft until 0 then keep note of how many clicks that was. Then start clicking it to maximum and see how many clicks that is. Mine is 30 hard max. Right now it's set to 10 hard front and 7 rear. For my HLSH, the first 10 clicks is linear dampening, after that the damping rate is fixed/constant. So if I want comfort, anything below 10 for me.
Mine is 20 from min to max (soft to hard) First set to 10/10, too hard. Now on 6/6, maybe need to increase the front...:rolleyes:
R34 carbon monitor from Duke Racing japan
