Caution: -Bad English- sorry
the idea came when changing new bumper .. noticed that be4 tis using promote bumper my engine will cooling quicker compare current bumper (special edition). Maybe the design itself (promote holes bigger than SE bumper) cause this problem. Plus, adding reg. plate no. will block more cold air goin' through the radiator (really?)
So... I need the flipper for the plate.
items needed:
2 x motor (fm digital aircond blower box)
metal bracket
power window switch
DIY tools
Motor (use 2 for left and right)
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-snc7/430954_10151287958144350_439693795_n.jpg
Using 1 side motor only, the other side need to remove motor inside the casing). Solder 2 wires direct to motor coz i dun hv the socket.
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-frc1/734553_10151287957929350_59594119_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash3/526005_10151287958259350_863572221_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-snc6/249926_10151287958269350_2114270923_n.jpg
made a additional holder fm thick aluminium, than rivet to the holder @ motor casing. Both side.
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash4/375234_10151287958389350_1233080149_n.jpg
Perfect (so far)
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-snc7/574997_10151287959024350_2120781626_n.jpg
try put @bumper
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash4/229903_10151287959539350_618693455_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-snc6/206488_10151287958694350_1045198509_n.jpg
Cutting and clearance checking process using cardbod
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-snc7/309441_10151287960099350_999379776_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-ash4/400065_10151287960149350_985433848_n.jpg
Seal around using gasket gum (what a waste). Supposed use silicon gum but lazy enuff go to hardware shop.
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash3/548221_10151287960134350_342892086_n.jpg
Put back @bumper and connect 2 motor holder with metal bracket. Than put the reg plate.
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-snc7/375309_10151287960254350_2138261414_n.jpg
Using this diagram on power window switch to control flip up and down
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash4/386722_10151287988489350_1265939832_n.jpg
Done. Dunno how to put video here..but can view here d3c3pt1c0n: DIY Homemade Flipper
Result: Ok la so far..Next project will be indicator for fully flipped up or fully flipped down.
items needed:
metal bracket
power window switch
DIY tools
Perfect (so far)
try put @bumper
