Actually, if you don't mind me asking what sort of maintenance did you have to do when you got the car and how much is it costing you to maintain the MarkX?
So far just the below:
- 6 iridium spark plugs cause found out that they use Camry spark plugs which is different heat range. Price is depending what plugs you want to buy.
- 6ltrs engine oil per change,which is also depending on how much you're willing to spend (I only bought Mobil 1 Full Synth from Tesco when on discount, so it's only rm210 for 6ltrs). Oil filter about rm50, but a few months ago I find out from the club where to get for only rm35.
- Brakes I did upgrade cuz the std brakes sucked! I spent just a bit over 2k for this upgrade (pads, rotors, brake hose). This is the biggest expense for me on the maintenance. Others in the club spend >3k to replace the front with new 4 pot BBK from GS300 which is plug & play to Mark X.
- Decarbonizing and fixing fuel line vibration due to the in-tank fuel pump assembly got air leaks/bubling, paid rm300.
That's about it. The other things I did were not maintenance but more about mod or add-on.
Next up on my maintenance list in about a months time are ATF, differential oil, and aircon oil & gas which should be similar to any other Toyota.
Btw note that I bought recon car that comes with 1yr warranty so that's why I have not change all fluids yet like normal as I just follow their recommended schedule. Now after 1yr warranty expires, then will change the rest. So far so good though. :)
