got forumer perdana auto close when switch off the car? my dad e36 can la..haha
anyway,
im using 2000 v6 perdana 1st batch. Basically what do to increase slightly my car performance as i sometime like to cruise at 140-150km/h. Just to compensate the soundproof material weight i install for the car.
i never had touch the ecu/tranny ecu. nothing is wrong but should i do something check/reflash/retune?
keeping engine NA and stock as possible. What i have in mind is :
-change air drop in air filter
-ignition plug
-exhaust system
-lighter rim
is there anything else or above are unnecessary?
I also year 2000, V6
e36, nice... before i got my v6, i was looking for a e36 with 1jz.. but exceed my budget..
is yours an auto or manual? mine is a manual.
i already change my air filter, drop in K&N, not bad. can feel the car breathe better.
Ignition plug, my advice is don't waste money, does not help. I have another savvy that using aftermarket ignition plug, after sometime, the engine will vibrate.. mechanic say it's the plug that causing this.
So stick to original, always better. Change to iridium spark plug if you can.
I got my bosch iridium at rm130 for 4, lifespan is 100k, also help you to save money in the long run.
Exhaust
Yes, it will helps but don't change extractor. stick to original.
as for the piping, go for straight through if you can.
It would definitely helps.
Lighter rim
it's always a bliss to have but be mindful, lighter rim usually cost more.
maybe we can do a mini meet up?? but i located in jb and work in singapore..
So the only time i get to see my car is only weekend.
as of now, i miss my v6..
