self poison
kurt_629
johor
some self poison parts..
Bosch rotor - front & rear
Bendix metal king - front & rear
standard spring - front & rear
17 rim & tire - 205/50/17
thinking of gettin samco hose, i know nothing special.. just aesthetic only.. :biggrin:
Should i get Billion thermal wrap? i read that it give a little boost but also need to consider, it will get wet and rust will come in. thinking of adding waterproofing coating to protect.
The wrap is for extractor or the whole exhaust system?:itsme:
As mine is a manual, only 6A12.
should i add another cooler for my engine oil or our stock radiator is suffice enough..
just wanna learn.. although i know i should save the money.. getting house and getting married..
just can't resist the self poison dosage.. :banghead::banghead:
bro, wire tuck is when ur engine is tidy and clean with no or little wire/hose visible as an act of aesthetic make up... check this out
i see, that's nice.
seriously, i think i need to do this. haha, mine is very messy.. normally done only by mechanic right??
sure la bro mechanic... but if ur competent, just DIY...:biggrin:
---------- Post added at 11:47 AM ---------- 6 hour anti-bump limit - Previous post was at 11:46 AM ----------
modding car is not only about going fast bro..
yeah, that's right.
apart from this, what are the other poison that i can consider??? :biggrin:
if u die of self poisoning that is a big sin hehehe.just sell your car n get mine instead. raise your hood a little so under bonnet temperature lower abit coz the hot air got more excape route.the plastic thingy n sensors will last slightly longer without getting rapuh/crunchy? lol. flush n clean out your radiator with all d hoses.change is ok if the rubber hardened. then go for port n polish.
wah lau.. i just got my v6 not more than 1 month..
it's a weekend car as most of the time, i'm working in singapore..
only go back JB on weekend..
I think the bonnet raising, it's adding washer. i have seen people doing it, the result surprising does not help at all. there's even dyno and temperature taking, before and after.
it does not work..
yeah, i'm going for Samco hose, model is 31191. i saw people selling online rm85 for full set, i try to find if jb selling that.
so you too are from ipoh, we will be returning to Ipoh on Oct, maybe can do a small kopi session. :biggrin:
it does not work..
The RM85 "samco" hose full set is ayam brand......
This is my list. Keeping NA v6 as it is. might consider manual tranny once it kong. This listed item are from works engineer.
-Fuel regulator stage 2
-cam gear 4piece(adjustable n light)
-air charger
-radiator hose
-piggyback
then:
-GAB adjustable suspension
-exhaust system(Header SS 6-2-1 design with
SS Flexible pipe,2pcs of 12" SS center resonator,SS 2" Full-Link Piping,SS S-Flow Rear Resonator quiet),SS Tailpipe)
-rim 17/18"
:biggrin::thefinger::biggrin::driver:
-air charger
-radiator hose
-piggyback
then:
-rim 17/18"
sound fierce, but some questions
-Fuel regulator stage 2 -cam gear 4piece(adjustable n light) -air charger -exhaust system(Header SS 6-2-1 design with
-rim 17/18"
are you looking at changing the extractor? got 6-2-1??? i only thought 4-2-1..
i don't know much about exhaust but likely, i will remove cat, resonator and change to 5zigen s flow muffler. manual can also use s flow right? :biggrin:
don't know by doing the basic thing for exhaust, will there be increase of hp or some noise :biggrin:
mine now, very silent.. which is quite boring..
---------- Post added at 09:28 AM ---------- 6 hour anti-bump limit - Previous post was at 09:19 AM ----------
For me, I only did these at present moment:
Done:
- Re condition of engine, brake oil, iridium, coolant, steering, K&N drop in
- Tinted
Currently doing:
- 17’ rim with 205/50/17
Intending & bought:
- change to stock spring
- bosch rotor
- brake pad
- 4 x additional reverse light
- 4 x projector light as fog light
- HID
- DRL
- Aesthetic like diamond as interior is VIP concept , pedal,
- Fire extinguisher
- Add on 4mm security film
- Soundproof pad for engine hood, mine only half currently..
- 13’ momo steering with quick release boss kit
hmm.. u should go with full exhaust system and drop-in performance filter.. then go for performance cable plug and iridium plug (6 pcs expensive woo).. then ur car will feel faster can cucuk2 at hiway... :driver:
what do you mean by full exhaust system?
share and enlighten me :confused:
my savvy is using performance cable, nothing special..
yeah.. iridium plug quite costly, got it at rm130 for 4 pcs..
total rm260 for 8pcs
Full means from the extractor to the tip. Haha.
Extractor is only extractor ma.
the best effect should be from extractor, downpipe & a performance muffler. go check some thread here post the exhaust setup for v6. then go get works drop-in filter. u live in johor go find works shop at masai if im not mistaken. then go find spitfire or ralliart or ngk blue plug cable,
u will feel the different if ur engine petrol is in high volume. it means, the fuel system is not stock anymore.. if u have extra cash, go get iridium. if not, enjoy as it is first. :biggrin:
Kurt : I would consider other brakepads. Bendix Metal King are great when warmed up. But when cold they can cause accidents.
-Fuel regulator stage 2 COLOR]
-cam gear 4piece(adjustable n light) COLOR]
-air charger COLOR]
-rim 17/18"
Yes 6-2-1 custom
not sure about hp..maybe some..but acceleration improvement is there.
Done:
- Tinted
Currently doing:
Intending & bought:
- bosch rotor
- brake pad
- HID
- DRL
- Fire extinguisher
just did recently aside from engine top overhaul,gb etc.. tinted rhineproxd3 RM680 4mil 58%..brembo rotor oem RM250 with installation..and osram nb+:driver:
i thought 6 pcs is around 2xx bosch :listen:
