if for std pv6 gates should be sufficient, if for 6a12tt better go for dayco.
ermm, at what mileage should we do an overhaul?
what is port and polish? involved in what part?
if u experience white smoke emitting from your exhaust even your engine has warmed up then its time for top overhaul.
YYC,
sure bo rm4k for new engine, engine kosong edi rm1.5k. TT rm2k.
YYC,
port n polish very subjective in term of pricing.so they take out the engine cylinder head.port is enlarge d tracts n intake holes etc.after that must polish to ensure smooth airflow ma.so ur engine can get more air to make more powderful combustion. and then the inner side is bling bling no carbon
Serious? 6A12tt, for only 2k??
I see, pardon me. I'm a newbie..
A question, if you spend 2-3k for polishing..
Why don't you use the money for a new engine purchase?![]()
and what are the interval for changing top gasket?
i keep in mind that for perdana overhaul at 100k km interval![]()
hi guys... long time no post... master twin turbo need your help ...
Twin Turbo Drive shaft is it easy to find or can use normal V6NA.
Driver side d. shaft, if i floor it can feel it's vibrating. When turning right can feel is stressing. Normal cruising is fine no sound.
I heard TT drive shaft (short) can use normal V6 NA drive shaft. Is it rue?
Which is the long and short?
Pls help.
oit.. sini pon ada ka?
rather than changing this and that, simpan duit and plonk in turbo engine la.![]()
ada la..hahaha.. v6 syiok smooth and stable..
but 0-100 no fun:slug:
hehe.. u'll be surprised on how smooth 4G63T engine on high speed cruising. well at least my car la..
quite rough on low speeds and acceleration but smooth during cruising..![]()
)hehe.. u'll be surprised on how smooth 4G63T engine on high speed cruising. well at least my car la..
